5. Maintaining Account, Rate, and Charge Details
Once you have captured the basic information required for processing clearing transactions in Oracle FLEXCUBE, you have to maintain information that would be required to process clearing transactions involving a specific product. In the Account, Rate, and Charge (ARC) Maintenance screen, you have to maintain information that will be used to:
Note
In order to compute applicable charge, the following screens need to be maintained, be­fore proceeding with ARC Maintenance:
Details on the above mentioned maintenances are provided in subsequent sections of this chapter.
5.1 ARC Maintenance Screen
5.1.1 Invoking ARC Maintenance Screen
The ARC Maintenance screen can be accessed from the Application Browser. You can invoke this screen by typing ‘IFDATMMN’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
In the ARC Maintenance screen, you primarily define parameters for processing clearing transactions involving a specific product, currency, and branch combination, and involving a specific Clearing House (in case of an inward clearing transaction) or a Sector (in case of an outward transaction). Towards this, you must specify the following details:
If you are maintaining ARC details for a product and a specific clearing house/sector, the details maintained in this screen will be used for posting entries generated by clearing transactions involving the product, clearing house/sector, branch and currency code combination.
Note
You must maintain ARC details for all possible combinations of products, currencies, branches, and clearing houses/sectors.
Product
In the ARC Maintenance screen, you have to first of all indicate the clearing product for which you are maintaining ARC details.
Transaction Type
Specify the type of transaction for the ARC maintenance. This adjoining option list displays all valid transaction types maintained in the system. You can choose the appropriate one.
Currency
ARC details are maintained for a product, branch, currency, and clearing house combination. Indicate the currency of the combination in the currency field.
Branch
The ARC record is maintained for a Branch + Product + Type + Ccy.
Account Class/Product
ARC record can be maintained for a Module specific Product Combination or for a specific Account Class level.
Note
The ARC pickup is based on Customer Group code in addition to branch- product-custom­er-transaction currency and customer. If an ARC record is not maintained at a branch-product-customer-currency level, system checks the ARC record for branch-product-cus­tomer group-currency before doing a wild card search.
The order of replacement of the parameters with wild card entries will be done based on the following order:
Customer Group
Specify the customer group to define charges. This adjoining option list displays all valid customer groups of type charge maintained in the system. You can choose the appropriate one. Input to this field is mandatory.
Account Class Group
Select the account class group from the adjoining option list.
Note
If ARC is maintained for an account class group, then the charges computed is applicable for all the account classes defined under that account class group,
The ARC resolution logic is as below:
Sequence
Account Class Group
Branch
Product
Currency
Customer Group
Transaction Type
1
Specific
Specific
Specific
Specific
Specific
Specific
2
Specific
Specific
Specific
Specific
Specific
3
Specific
Specific
Specific
Specific
Specific
4
Specific
Specific
Specific
Specific
Specific
5
Specific
Specific
Specific
Specific
Specific
6
Specific
Specific
Specific
Specific
7
Specific
Specific
Specific
Specific
8
Specific
Specific
Specific
Specific
9
Specific
Specific
Specific
Specific
10
Specific
Specific
Specific
Specific
11
Specific
Specific
Specific
12
Specific
Specific
Specific
13
Specific
Specific
Specific
14
Specific
Specific
Specific
15
Specific
Specific
16
Specific
Specific
Specific
Specific
Specific
17
Specific
Specific
Specific
Specific
18
Specific
Specific
Specific
Specific
19
Specific
Specific
Specific
Specific
20
Specific
Specific
Specific
Specific
21
Specific
Specific
Specific
22
Specific
Specific
Specific
23
Specific
Specific
Specific
24
Specific
Specific
Specific
25
Specific
Specific
Specific
26
Specific
Specific
27
Specific
Specific
28
Specific
Specific
29
Specific
Specific
30
Specific
Indicating Offset Details
You can indicate the offset currency to be used for processing FX contracts involving different currency combinations. Exchange rate for the contract is based on the rate code and type defined for the currency combination in the Retail Teller product definition, Product preference screen. Based on the transaction currencies chosen and the exchange rate defined for the currency combination, the system will pass the relevant accounting entries.
Note
The Offset currency field will be enabled for all products and not for account classes.
The ARC pickup in branch and host will be based on offset currency in addition to branch, product, transaction currency, customer and customer group. The order of replacement of the parameters with wild card entries is done in the following order:
For FX transactions, the second currency from FX screens is used as offset currency for ARC pickup. For RT transactions, offset currency will also be used for ARC pickup.
The order of replacement of the parameters with the wild card entries will be as per the matrix given in the Annexure I.
The Rate code and type pickup in branch and host for the Retail transactions will be from the product preferences for the currencies involved in the transaction. If a record is not maintained for the given product and specific currency combination, the system will check for the currency combinations given in Annexure II. If no record is found for all the given combinations, the system will pickup the rate code and type from the product definition.
Indicating the Offset Details
You can specify the branch and the offset account or GL into which offset entries are to be booked. In case of an inward clearing transaction, this would typically be the Liability GL for Inward Checks to which the credit entries would be posted. (The customer account would be debited.) In case of an outward clearing transaction, this would be the Liability GL maintained for Outward Checks to which the debit entries would be posted. (The customer, in this case, would be credited.)
Indicating Transaction Details
You can specify the branch and the account number in which the transaction is taking place. The account in this field is the customer account. In case of inward clearing transactions, this account number would be available on upload of clearing transactions.
Indicating Transaction Codes
A unique Transaction Code identifies all transactions in Oracle FLEXCUBE. As part of ARC maintenance, you can indicate the offset transaction code and the main transaction code. You have to choose a transaction code for which the status of the option ‘Cheque Mandatory’ is checked at the definition. By this, the system can track the used cheques.
End Point
If you are maintaining ARC details for an outward clearing type product, you should specify the branch, the currency, and the sector code that are part of the combination. In addition, you should specify the end point (or clearing house) to which branches in this sector report to and the bank and customer float days.
If you are maintaining ARC details for an inward clearing type product, you should specify the branch, currency, and end points that form part of the combination.
From the pick list available in the Clearing House field, specify the Clearing House for which you are maintaining ARC details.
Clearing Houses are also referred to as End Point Codes in Oracle FLEXCUBE. Select the End Point Code of the Clearing House in the End Point field.
Generate MT101
Check this box to generate MT101.
Bank and the Customer Float Days
“Float days,” indicate the number of days that are added to the booking date of an outward clearing transaction to arrive at its value date (that is, the day on which an account is actually debited or credited with funds). As part of the ARC Maintenance for a transaction type, you have to indicate the Bank and Customer Float days.
The term “bank float days” refers to the days that will be used to calculate the value date of the bank leg of a transaction. The term “customer float days” refers to the days that will be used to calculate the value date of the customer leg of a transaction. The following example illustrates the implications.
If you have maintained float days, the system will validate the Clearing House Holiday Maintenance also.
Note
You can choose to maintain an ARC Wildcard record for a Branch, Currency and Custom­er combination or for any one or more of these entities. Ensure that the wildcard symbol that you are using is a *.
Float Days Basis
Float days applicable for outward clearing customer transactions are defined through the Customer Float Days Maintenance screen. The float days can either be considered as:
You can select the appropriate option, which will be used to arrive at the value date for outward clearing customer transactions.
For details about defining float days for a customer or customer group, refer the Core Entities user manual.
Charge Debit Account
You can choose the charge debit account from the adjoining drop-down list. The available options are:
Netting Charges
You have the option to net the accounting entries for the debit leg of the charges along with the main transaction entries.
Check this box to indicate that the debit leg of the charges is to be netted before passing the accounting entries. Leave the box unchecked to pass the entries without netting the charges of the debit leg.
Main Offset Accounting Entries Required
If this box is checked, the system will pass the main accounting entries along with charges defined at ARC for a Product. Otherwise only the charges accounting entries defined for the product will be passed which is used for online charge collection.
Note
When RT products are used for On-line charge definition (STDCHGMN), then this check box has to be unchecked.
Generate Transaction Advice
Whether an Advice needs to be generated for the Transaction (redundant for J2EEBranch, might still be used for other Interfaces).
5.1.1.1 Indicating Service Charges for Inter-branch Transactions
In a transaction, if the account branch of the teller transaction is different from the transaction branch, then charges maintained by inter-branch product will be applied to the transaction.
If you select the IB transaction as 'Yes' for a RT product at ARC, the system picks up and process the charge entries as maintained.
If you select the IB transaction as 'NO' for a RT product at ARC, then the charges maintained in non-ib product are applied to the transaction.
IB Transaction
Check this box if you want the system to pick up the product, for inter-branch transactions.
You will notice the difference in the service charges processed for two transactions with same kind of product.
Note
This will be supported for Cash Deposit (1401), Cash Withdrawal (1001) and Account to Account Transfer (1006)
5.1.1.2 Indicating Exchange Rate Revaluation
You can specify the following details:
Profit Revaluation GL
Specify the profit revaluation GL details.
Loss Revaluation GL
Specify the loss revaluation GL details.
5.1.2 Defining Charge Details
You can define a maximum of five charges. A charge can be computed based either on the transaction amount or on an earlier charge amount
As part of defining the Charge details for each charge, you need to capture the following details:
Charge Type
The Charge Type that should be applied on the transaction. It could either be a Percentage of the transaction amount or a Flat Charge.
Slab Type
Whether the Charge computation has to be over different Amount Slabs or Tiers (0-100 @ 10, 101-500 @ 15 etc.).
Basis
You can indicate the basis amount on which the charge is to be computed.
Since you can maintain five different charge amounts, the basis amount that you enter could either be the ‘Transaction Amount’ or any of the earlier charge amounts. For example, let us assume you are maintaining Charge 1. The only basis for charge 1 can be the transaction amount. While defining Charge 2 you can choose either the transaction amount or Charge 1 as the basis. Similarly while defining Charge 3, you can choose the transaction amount or Charge 1 or Charge 2 as the basis. NUM-ACC=OPN-DAYS' is used as basis to define the Account closure Charge product. When this basis is used, Slab type should be maintained as "SLAB”. As system will check the slab for charges to be collected based on the Number of days account kept open by the customer. ‘System Entity’ can be selected to calculate those teller transactions that exceeds the restriction amount. If ‘System Entity’ is selected, then the linked system entity returns the basis amount on which the charge is calculated.
Entity Name
The field is enabled if ‘System Entity’ is selected in the ‘Basis’ field. Select the Entity Name, from the adjoining option list. The list of values are populated from the ‘Entity Maintenance’ screen (STDENMNT). Further details on the ‘Entity Maintenance’ screen is provided in subsequent sections of this chapter.
Based on Charge Code
Check this box to indicate whether the charge is based on the charges maintained in the charge code maintenance. If this field is checked, then the system checks the parameters applicable to the said charge code from the Charge Code Maintenance (which is detailed in the subsequent section) and passes the relevant parameter value(s). The system also passes the “Basis” amount to the charge code as the basis is captured at ARC charge level.
If the system is unable to pass a parameter value to a charge code because of unavailability of data, the same parameter is treated as *.*.
Subsequently, charges are calculated based on the charge calculating preferences for the said record. Charge Code
This field is enabled if ‘Based on Charge Code’ field is checked. Select the charge code from the adjoining option list. All charge codes as maintained in the charge code maintenance screen is listed in this field.
Currency
You can indicate the currency in which the charge amount would be expressed. If the transaction currency is different from the charge currency, a conversion would be done, using the rate code and rate type that you specify for each charge.
Their Charges
For outward clearing checks, you can indicate whether the charge is being collected on behalf of the collecting bank. If you set this option, you need not specify the charge account. Since the charge amount would not known upfront, you need not specify the amount either.
This can also be used to indicate the charge product is used to collect the presenting bank charges in case of Outward Returns.
Select the charge debit account into which charge related entries are to be posted from the adjoining option list.
Note
Charge Credit Account
Select the charge credit account from the adjoining option list. The other leg of the charge is posted to a GL, as specified in the ARC record.
For example,
To collect tax from the income received will be as follows:
For cash deposit transactions, bank wants to collect a charge of 5% on the transaction amount (inclusive of tax). The bank has to remit Tax @ 9.090909% of gross charge collected from the income GL.
The ARC maintenance can be done as follows to achieve the same:
Charge 1:
Charge Basis: Transaction Amount
% Charge: 5 %
Charge Debit Account: Transaction Account
Charge Credit Account: Income GL (say INC00001)
Charge 2:
Charge Basis: Charge 1
% Charge: 9.090909%
Charge Debit Account: Income GL (INC00001)
Charge Credit Account: Tax Payable GL (say PAYB0001)
For a cash deposit of USD 1000 in account CASA0001, the gross charge (inclusive of tax) will be USD 50 and Tax will be 4.55 after rounding.
The accounting entries for the maintained ARC will be as below:
Dr/Cr
Account
Currency
Amount
DR
CASH GL
USD
1000
CR
CASA0001
USD
1000
DR
CASA0001
USD
50
CR
INC00001
USD
50
DR
INC00001
USD
4.55
CR
PAYB0001
USD
4.55
Netting Charge
If two or more accounting entries, for the same event, are to be passed to the same account, on the same Transaction Date, these entries can be netted. You can choose to net charges by choosing this option.
Transaction Code
You can indicate the code using which the accounting entries would be booked, for each charge.
Rate Code and Rate Type
While settling charges for cross currency transactions, you can choose to debit the customer by applying the mid rate, buy rate or by using the buy/sell spread over the mid-rate. Therefore, you need to specify the Exchange Rate details for each ARC definition record that you maintain in the system.
Firstly, indicate the Rate Code for which different rates can be maintained. A list of all the rate codes maintained in the Floating Rates Maintenance screen is displayed in the list. You can choose the appropriate code.
In addition to specifying the Rate Code, you have to indicate the Rate Type which should be picked up for exchange rate conversions involving settlement of charges for cross currency transactions. You can maintain any one of the following as the Rate Type:
After identifying the Rate Code and Rate Type you can indicate the basis amount on which charges are to be computed.
Amount
You have to specify the flat amount only when the charge type is a Flat Amount.
The flat amount will be collected in the currency that you have specified in the Charge Currency field.
Rate
If you have indicated that the charge should be a percentage of the transaction amount, you have to necessarily capture the rate that is to be applied on the transaction amount. The rate that you specify will be applied after converting the amount into the Account Currency.
Minimum and Maximum Charge Amount
When the charge type applicable on the transaction is a percentage of the transaction amount you have to capture the minimum and maximum charge amounts that should be applied on the transaction.
If the charge percentage involving a particular transaction is less than the minimum charge, the system will, by default, debit the customer account with the minimum charge amount. If the charge percentage exceeds the maximum amount, the system will debit the customer account with the maximum charge amount.
Note
The charge amount will be deducted in the currency that you specified in the Charge Cur­rency field.
MIS Head
Specify the MIS Head that is applicable for the charge-related accounting entry.
Description
You can indicate a short description for the charge.If you have provided a charge, it is mandatory to enter the description.
Charge Tracking Preference
Select charge tracking preference from the adjoining drop-down list. The options available are:
Note
Note
Liquidation Preference for Tracked Charges
Note
The system displays override messages when:
The non sufficient funds tracked transactions can be reversed on the same day only, next day reversal is not allowed.
If netting is disabled for credit transactions, the charges will be deducted from the account. Hence, NSF charge tracking preference will be applicable if system is unable to collect the charge amount.
For further details refer ‘Maintaining Accounting Details’ chapter of Retail Teller user manual.
5.2 Charge Code Maintenance
This section contains the following topic:
5.2.1 Invoking Charge Code Maintenance Screen
In the ‘Charge Code Maintenance’ screen, charges based on some additional parameters which are not part of ‘ARC maintenance’ can be maintained. The charge matrix in this screen can be attached to the ARC maintenance screen for arriving at charges based on additional parameters.
You can invoke this screen by typing ‘STDCHGCD’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
Specify the following details in this screen:
Charge Code
Specify a unique identifier to identify a charge code.
Charge Code Description
The description of the charge code will be defaulted here.
Parameters Mapping
In this section, actual parameter(s) based on which charges are differentiated is mapped to fixed parameter IDs. There are 5 parameter IDs provided in this section. At least one parameter should be mandatorily defined. Select the appropriate value from the adjoining option list. This list contains the following values:
The list of factory shipped parameters which is made available in this screen are as follows:
Parameter Specific To
Differentiating Parameter
Description
Applicable to transaction
Customer
CUSTOMER_CATEGORY
Customer category speci­fied at customer CIF level
ALL
GROUP_CODE
Group code specified at customer CIF >Addi­tional tab level
ALL
CLEARING_GROUP
Clearing group specified at customer CIF >Addi­tional tab level
ALL
TAX_GROUP
Tax group specified at customer CIF >Addi­tional tab level
ALL
CUSTOMER_CLASSIFICA­TION
Customer Classification specified at customer CIF >Additional tab level
ALL
NATIONALITY
Nationality specified at customer CIF level> per­sonal/corporate tab
ALL
Transac­tion
TRANSACTION_BRANCH
Branch code at which transaction is being done
ALL
TRANSAC­TION_BRANCH_GROUP
Branch group to which transaction branch belongs to
ALL
ACCOUNT_BRANCH
Branch code of the trans­action account
ALL
ACCOUNT_BRANCH_GROUP
Branch group to which account branch belongs to
ALL
PAYABLE_BANK_CODE
Payable bank code for BC/DD/TT
BC/DD/TT
PAYABLE_BRANCH_CODE
Payable Branch for BC/DD/TT
BC/DD/TT
TO_ACCOUNT_BRANCH
Branch code of the Credit account
LOCH and Account to Account transfer
TO_AC­COUNT_BRANCH_GROUP
Branch group to which credit account branch belongs to
Charge Matrix
Values 1 to 5
Values 1 to 5 correspond to the respective parameter values in the Parameter Mapping section. For example Value 1 corresponds to Parameter Value 1 and so on and so forth. Select the specific values from the adjoining option list.
Charge Type
Select the charge type from the drop down list. The charge type can be flat or percentage.
Amount
Specify the charge amount in this field.
Rate
Specify the rate in this field.
Minimum Charge
Specify the minimum charge in this field.
Maximum Charge
Specify the maximum charge in this field.
Slab Type
Select the Slab Type as Slab or Tier from the drop down list. If Slab Type is Slab or Tier, then provide the slab or tier details in the slab or tier sub-screen by clicking ‘S’ button.
In this screen, you need to specify the number of slabs, the basis to value, and charge slab details.
5.3 ARC Branch Group Maintenance
5.3.1 Invoking ARC Branch Group Maintenance
To define branch groups which are equivalent to cities or regions that the bank operates in, invoke the ‘ARC Branch Group Maintenance’ screen by typing ‘STDBRGMT’ in the field at the top right corner of the application tool bar and clicking the adjoining arrow button.
ARC Branch Group
Specify a group code to identify a group of branches.
ARC Branch Group Description
Specify a description for the branch group.
After specifying details in the ‘ARC Branch Group Maintenance’ screen, all the ARC branch groups are displayed in the ‘Branch Parameter Maintenance’ screen (STDBRANC). Select the branch group from the ‘ARC Branch Group’ field.
For more information on the Branch Parameters Maintenance screen, refer section 5 ‘Branch Parameters’ in the Core Service module.
5.4 Entity Maintenance
5.4.1 Invoking Entity Maintenance Screen
In the ARC Maintenance screen, fees or charges as a percentage of the transaction amount can be calculated for transactions exceeding the restriction amount. To calculate this fee or charge, you need to select ‘System Entity’ in the ‘Basis Field’ in the ARC Maintenance screen. Thereafter, the ‘Entity Name’ field is enabled which displays values obtained from the ‘Entity Maintenance’ screen. You can invoke this screen by typing ‘STDENMNT’ in the field at the top right corner of the application tool bar and clicking the adjoining arrow button.
Specify the following in this screen:
Entity Name
Specify the entity name to be considered for Fee Maintenance.
Unit Name
Select a value for charge consideration from the drop down list. The value provided in the drop down list are as follows:
During ARC Maintenance, the following scenarios are considered if exceeded amount is selected:
During ARC Maintenance, the following scenarios are considered if transaction amount is selected
Entity Type
Select the Entity Type from the drop down list. The values provided in the drop down list are as follows:
Parameter
Select the Parameter if ‘Restriction Code’ is selected in the Entity Type field, from the adjoining option list. All active restriction codes as maintained in the system are displayed in this field. For more information on restriction code maintenance, refer to the section ‘Restriction Amount Maintenance’ in the Core Services Module.
5.4.1.1 Viewing Entity Types
You can view the entity types in the ‘Entity Summary’ screen. You can invoke this screen by typing ‘STSENMNT’ in the field at the top right corner of the application tool bar and clicking the adjoining arrow button.
You can search for entity types by specifying values in the following fields:
On updating these details and clicking the ‘Search’ button, the following columns are populated:
5.4.1.2 Specifying Regulation CC Availability for Clearing Products
In addition to the accounting entry and charge definition you will also have to maintain the following ARC details to incorporate the Regulation CC requirements:
Note
Availability depends upon the specifications in the Clearing House Holiday Maintenance and the Branch Holiday Maintenance. The value date is first arrived at using the clearinghouse calendar, and if it happens to be a branch holiday, it is moved to the next working day.
During transaction processing the value date for Reg CC availability for the check deposit gets defaulted based on the Credit Account and the ARC Maintenance for the Clearing Product.
To specify the Reg CC details, click ‘Regulation’ button in the ARC Maintenance screen. The Reg Details screen is opened, where you can specify the details.
The schedule for the availability of funds for check deposits under Reg CC will be calculated in the following manner:
For local and non local checks when the aggregate deposit amount in a day < 5000
Schedule
Day
Amount
Sch1
Transaction day + 1
100
Sch2
Available day – 1
400
Sch3
Available day
Balance
For local and non local checks when the aggregate deposit amount in a day > 5000
Schedule
Day
Amount
Sch1
Transaction day + 1
100
Sch2
Available day – 2
400
Sch3
Available day - 1
4500
Sch4
Available day
Balance
For federal or special checks the funds are made available only on the next business day irrespective of the amount deposited, and the checks are not considered for Regulation CC scheduling.
Account Statements
All the details of the checks deposited on a given day and the funds cleared as per the schedule will be displayed in the account statement.
