Limits and Collateral Management module provides a feature to maintain Facility details based on a particular value date. This is called the Vale Dated Facility. This facilitates the changes in the Limits Amount, Main Line Linkage etc. to take effect from the particular date.
LCM also tracks all the Utilizations of the Facility based on the value date of the transaction. The utilizations will take effect from the value date of the transaction onwards.
Note
LCM facilitates maintaining Facility details based on a particular value date. The changes in the Limits amount, Main line linkage etc. would take effect from the particular date.
The following parameters will be taken from the Facility Maintenance screen:
Whenever a new Limit Line is created, a new record will be automatically created by the system with the value date as the Limit Start Date. The Main Line and the Limit Amount will be same as the booking dated limit maintenance.
Whenever the Mainline or the Limit amount is changed in the facility, a new record will be created in the maintenance with value date as the application date. The mainline and limit amount values will be same as in the booking dated Limits maintenance. You can manually change the value to an older value date by clicking ‘Value Date’ button.
The ‘Conversion Date’ contains the date when facility was migrated from the external system to LCM. In the Facility screen this date will be displayed.
Back Valued Static Maintenance Changes
The value dated utilization details will be rebuilt from the value date of the change whenever the following static maintenances are done:
If the facility has been migrated then back valued static maintenance cannot be prior to the conversion date.
LCM also tracks all the utilizations of the facility based on the value date of the transaction. The utilizations will take effect from the value date of the transaction onwards.
The following transactions are supported for Value dated processing:
As part of the above utilization transactions, the Value Date will be the value date of the transaction. Updating of value dated utilization can be set to be online or to be a part of EOD process. This parameter is maintained in LCM Parameter Maintenance.
The following back valued operations will cause a rebuild of value dated utilization details:
If the utilization currency is not same as the line amount currency, then the system will convert the utilization into line amount currency and update the utilization. The exchange rate will be that of the value date of the utilization. So for back valued utilization the exchange rate on the value date of the back valued transaction will be used.
In case the Value Date is less than the conversion date, then the rebuild of balances will be from the conversion date only.
If the value date update is not online, but as part of Facility EOD process, it would be updated as shown in the following examples.
Example,
Let us consider a Loan of 1 Million USD. Value date 10-Jan-2005 Revolving Line
Step 1: Initiation - Utilization Log
S.no |
Value date |
Line code |
Utilization |
Component |
Increase/decrease |
1 |
10-Jan-05 |
LINE1 |
1000000 |
PRINCIPAL |
Increase |
Line Utilization
S.no |
Value date |
Line code |
Utilization |
1 |
10-Jan-05 |
LINE1 |
1000000 |
Step 2: Payment of 0.1M Principal value date 10-Feb-2005 - Utilization Log
S.no |
Value date |
Line code |
Utilization |
Component |
Increase/decrease |
1 |
10-Jan-05 |
LINE1 |
1000000 |
PRINCIPAL |
Increase |
2 |
10-Feb-05 |
LINE1 |
100000 |
PRINCIPAL |
Decrease |
Line Utilization
S.no |
Line code |
Value date |
Utilization |
1 |
LINE1 |
10-Jan-05 |
1000000 |
2 |
LINE1 |
10-Feb-05 |
900000 |
Step 3: Value dated amendment of 0.5M Principal increase value date 15-Feb-2005 - Utilization Log
S.no |
Value date |
Line code |
Utilization |
Component |
Increase/decrease |
1 |
10-Jan-05 |
LINE1 |
1000000 |
PRINCIPAL |
Increase |
2 |
10-Feb-05 |
LINE1 |
100000 |
PRINCIPAL |
Decrease |
3 |
15-Feb-05 |
LINE1 |
500000 |
PRINCIPAL |
Increase |
Line Utilization
S.no |
Line code |
Value date |
Utilization |
1 |
LINE1 |
10-Jan-05 |
1000000 |
2 |
LINE1 |
10-Feb-05 |
900000 |
3 |
LINE1 |
15-Feb-05 |
1400000 |
Step 4: Payment of 0.2M value date 10-mar-2005 - Utilization Log
S.no |
Value date |
Line code |
Utilization |
Component |
Increase/Decrease |
1 |
10-Jan-05 |
LINE1 |
1000000 |
PRINCIPAL |
Increase |
2 |
10-Feb-05 |
LINE1 |
100000 |
PRINCIPAL |
Decrease |
3 |
15-Feb-05 |
LINE1 |
500000 |
PRINCIPAL |
Increase |
4 |
10-Mar-05 |
LINE1 |
200000 |
PRINCIPAL |
Decrease |
Line Utilization
S.no |
Line code |
Value date |
Utilization |
1 |
LINE1 |
10-Jan-05 |
1000000 |
2 |
LINE1 |
10-Feb-05 |
900000 |
3 |
LINE1 |
15-Feb-05 |
1400000 |
4 |
LINE1 |
10-Mar-05 |
1200000 |
Step 5: Reversal of Payment of 0.2M value date 10-mar-2005 on 15-mar-2005 - Utilization Log
S.no |
Value date |
Line code |
Utilization |
Component |
Increase/decrease |
1 |
10-Jan-05 |
LINE1 |
1000000 |
PRINCIPAL |
Increase |
2 |
10-Feb-05 |
LINE1 |
100000 |
PRINCIPAL |
Decrease |
3 |
15-Feb-05 |
LINE1 |
500000 |
PRINCIPAL |
Increase |
4 |
10-Mar-05 |
LINE1 |
200000 |
PRINCIPAL |
Decrease |
5 |
10-Mar-05 |
LINE1 |
200000 |
PRINCIPAL |
Increase |
Line Utilization - Step 6 Liquidation of Contract Value date 10-apr-2005 - Utilization Log
S.no |
Value date |
Line code |
Utilization |
Component |
Increase/decrease |
1 |
10-Jan-05 |
LINE1 |
1000000 |
PRINCIPAL |
Increase |
2 |
10-Feb-05 |
LINE1 |
100000 |
PRINCIPAL |
Decrease |
3 |
15-Feb-05 |
LINE1 |
500000 |
PRINCIPAL |
Increase |
4 |
10-Mar-05 |
LINE1 |
200000 |
PRINCIPAL |
Decrease |
5 |
10-Mar-05 |
LINE1 |
200000 |
PRINCIPAL |
Increase |
6 |
10-Apr-05 |
LINE1 |
1400000 |
PRINCIPAL |
Decrease |
Line Utilization
Line code |
Value date |
Utilization |
1 |
LINE1 |
10-Jan-05 |
1000000 |
2 |
LINE1 |
10-Feb-05 |
900000 |
3 |
LINE1 |
15-Feb-05 |
1400000 |
4 |
LINE1 |
10-Mar-05 |
1400000 |
5 |
LINE1 |
10-Apr-05 |
0 |
