9. Error Codes and Messages
This chapter contains the following section:
9.1 Error Messages
Error Code
Message
FMS-0001
Duplicate FMS value
FMS-0002
Mapping already exists
GL-0001
Line code cannot be null
GL-0002
Line code length cannot be less than three characters
GL-0003
Line description cannot null
GL-0004
Cannot change the line type
GL-0005
The line type of the parent does not match with that of the line
GL-0006
The category of the parent does not match with that of the child
GL-0007
$1 is the consolidation point for $2
GL-0008
Record already exists
GL-0009
First authorize the lines above the current line in the hierarchy
GL-0010
Enter valid parent
GL-0011
Mandatory fields not input
GL-0012
The length of the GL code cannot be lesser than three characters
GL-0013
Duplicate GL code, customer account or account short code
GL-0014
The GL code does not match with the GL Mask
GL-0015
Check digit could not be generated for the current GL code
GL-0016
The scope of currency restriction cannot be reduced
GL-0017
The scope of the branch restriction cannot be reduced
GL-0018
A head office or branch Restriction can be modified to both only
GL-0019
GL-0020
Some branches are not at End of Day
GL-0021
Closure disallowed. Customer Accounts linked to the GL at following nodes: $1
GL-0022
The type does not allow Modification
GL-0023
Balance for the current GL is not zero at following nodes: $1
GL-0024
First authorize the GL above the current GL in the hierarchy
GL-0025
Enter the currency
GL-0026
Current GL is a parent of some open GLs
GL-0027
The parent GL for the current GL has been modified to a leaf - cannot open this GL
GL-0028
Spaces not allowed in GL code
GL-0029
Length of the field cannot be less than three characters
GL-0030
A maximum of ten customer classes and ten transaction classes allowed
GL-0031
A maximum of two classes can be maintained for budget for each customer/transaction class
GL-0032
Input mandatory
GL-0033
Gl_Code cannot be null
GL-0034
MIS_Class cannot be null
GL-0035
Invalid record
GL-0036
The Parent_GL for the current GL is unauthorized - cannot open this GL
GL-0037
The Parent_GL for the current GL is closed - cannot open this GL
GL-0038
Before running the consolidated report run the GL report for the branch - $1
GL-0039
Could not generate the report
GL-0040
Failed to perform the consolidation for the nodes
GL-0041
GL code already used
GL-0042
Failed to update the Balances for the customer GLs
GL-0043
Budget name cannot be empty
GL-0044
Invalid budget description
GL-0045
Financial year cannot be empty
GL-0046
Period code cannot be empty
GL-0047
M I S class cannot be empty
GL-0048
M I S code cannot be empty
GL-0049
Currency code cannot be empty
GL-0050
Amount cannot be empty
GL-0051
Branch cannot be empty
GL-0052
No records available
GL-0053
GL code cannot be empty
GL-0054
All (AL) option cannot be selected, when a currency has been already selected
GL-0055
Input a valid date
GL-0056
Spaces not allowed in report name
GL-0057
Failed to perform consolidation
GL-0058
Spaces are not allowed in MIS class
GL-0059
Spaces are not allowed in MIS code
GL-0060
Change of MIS type is not allowed
GL-0061
Cannot delete the last detail record
GL-0062
Detail records cannot be empty
GL-0063
Duplicate record
GL-0064
All (AL) option has been selected, other currencies not allowed
GL-0065
Enter a valid category
GL-0066
Enter a valid category group
GL-0067
Cannot change the category of the line
GL-0068
Current line is a parent of some open lines
GL-0070
The parent line for the current line is closed - cannot open this line
GL-0071
The parent line for the current line is unauthorized - cannot reopen this line
GL-0072
Budgeting is being done for this GL. Closure disallowed
GL-0073
Reporting is being done for this GL. Closure disallowed
GL-0074
MIS update failed
GL-0075
Budget update failed
GL-0076
This report is being run by another user. Please wait
GL-0077
Type not allowed for customer GL
GL-0078
Type not allowed for internal GL
GL-0079
Category not allowed for customer GL
GL-0080
Financial year/period code cannot be null
GL-0081
Date cannot be null
GL-0082
Report name mandatory
GL-0083
Days cannot be greater than 27 if months present
GL-0084
Days cannot be greater than 364 if years present
GL-0085
Months cannot be greater than 11 if years present
GL-0086
Tenor cannot be negative
GL-0087
Period code cannot be null
GL-0088
Financial year cannot be null
GL-0089
Cannot change leaf to a node
GL-0090
Do you want to close the financial year?
GL-0091
Do you want to close the period?
GL-0092
Could not close financial year
GL-0093
Could not close period
GL-0094
Enter the financial year before the period
GL-0095
Cannot use this MIS class for further allocation order
GL-0096
Interbranch GL - only one MIS group allowed
GL-0097
Mandatory field MIS group cannot be null
GL-0098
A position GL or position eqv. GL cannot be defined as node GLs.
GL-0099
This process can be run only between end of financial input and End of Day
GL-0100
This process has already been run
GL-BUD01
Period code is not maintained for the budget
GL-BUD02
The MIS class 1 for the budget is not maintained
GL-BUD03
The MIS code 1 for the budget is not maintained
GL-BUD04
The MIS class 2 for the budget is not maintained
GL-BUD05
The MIS code 2 for the budget is not maintained.
GL-CPT01
This combination of product, allocation code, transaction type and MIS code for the given financial cycle and period code is already maintained
GL-CPT02
Product or allocation code or transaction type cannot be null
GL-CPT03
Both cost code and cost per transaction cannot be null
GL-CPT04
Financial cycle or period code cannot be null
GL-CPT05
The selected period code is not for the chosen financial cycle
GL-CPT06
Segment code cannot be null
GL-CTG1
Asset accounts should be of debit category
GL-CTG2
Liability accounts should be of credit category
GL-CTG3
Income accounts should be of credit category
GL-CTG4
Expense accounts should be of debit category
GL-CTG5
Invalid FMS account code
GL-DEBUG
1
GL-FIN­CL001
Finance closure successful
GL-FIN­CL002
Finance closure unsuccessful
GL-FMS1
The legal vehicle of the FMS account is not valid
GL-FMS2
Incorrect length of FMS account
GL-FMS3
The currency is not valid
GL-FMS4
The FMS account exists
GL-FMS5
The GL code is a new GL. Do you want to auto-maintain it?
GL-FMS6
The RC code is new. Do you want to auto-maintain it?
GL-FMUP001
Failed to get commit frequency for process ZDWU
GL-FMUP002
No data found in cotms_source_pref for source $1
GL-FMUP003
Failed to get upload ID for process ZDWU
GL-FMUP004
Failed to translate external entity $1 for $2 - check if it is authorized/open or not maintained
GL-FMUP005
GL - $1 closed
GL-FMUP006
GL - $1 unauthorized
GL-FMUP007
$1 duplicate GL
GL-FMUP008
$1 - failed to insert in GLTMS_GLMASTER
GL-FMUP009
$1 - failed to insert in STTBS_ACCOUNT
GL-FMUP010
MIS group - $1 closed
GL-FMUP011
MIS group - $1 unauthorized
GL-FMUP012
Failed to get the Maximum class number for transaction class
GL-FMUP013
RC01 - failed to insert into GLTMS_MIS_Class
GL-FMUP014
$1 - RC01 - failed to insert into GLTMS_MIS_Code
GL-FMUP015
$1 - $2 - failed to insert into GLTMS_GL_MIS_Group
GL-FMUP016
Failed to insert in GLTBS_FMS_Details
GL-FMUP017
Record already exists in GLTBS_FMS_Details
GL-FMUP018
$1 - $2 - failed to get start and end date
GL-FMUP019
EOM balances not sent by FMS
GL-FMUP020
AVG balances not sent by FMS
GL-FMUP021
LCY balance not sent but the currency is local currency
GL-FMUP022
No MIS head maintained for transaction code $1
GL-FMUP023
$1 - MIS group not maintained
GL-FMUP024
Failed to insert in MITBS_Class_Mapping
GL-FMUP025
Failed to update processed flag
GL-FMUP026
General failure in FMS upload process
GL-FMUP027
No records to process
GL-FMUP028
The record is already processed
GL-FMUP029
$1 cannot be null
GL-FMUP030
FMS upload successful
GL-FMUP031
Failed to insert in GLTBS_FMS_Master
GL-FMUP032
FMS and ISO currency should be same
GL-FMUP035
Account code invalid
GL-GRP01
Source group name cannot be null
GL-GRP02
Source group name should be unique
GL-GRP03
Please maintain at least one GL code for this group
GL-POS01
Currency field cannot be null
GL-POS02
At least one of the fields (position GL or position eqv. GL) has to be populated
GL-POS03
GL is linked for positioning in GL maintenance - cannot be closed
GL-POS04
GL is linked for positioning in currency maintenance - cannot be closed
