3. Annexure
3.1 Accounting Handoff from External System to FCUBS
An external system can request for debit or credit to an account or GL in FCUBS through the interface.
The following major values will be passed as part of debit request for accounting handoff:
Values
Description
Mandatory
MODULE
Module which is sending for accounting handoff
Yes
TRN_REF_NO
Transaction reference number for debit / credit
No
EVENT_SR_NO
Event serial no for Dr / Cr leg
Yes
EVENT
Event against which accounting to be posted
Yes
AC_BRANCH
Branch for accounting handoff
Yes
AC_NO
Account to which Debit / Credit to be done on accounting handoff
Yes
AC_CCY
Currency of the account
Yes
DRCR_IND
Account to be debited / credited on accounting handoff
Yes
AMOUNT_TAG
Amount tag against which accounting to be posted
Yes
LCY_AMOUNT
Local ccy amount for accounting handoff
Yes
ECAREFNO
ECA reference no generated for each request under a ECA create external reference no
Yes (Man­datory for ECA Debits only)
FCYAMT
Fcy amount for accounting hand­off, Mandatory, if Account cur­rency is Fcy.
No
EXCHRATE
If Ccy is Fcy, then exchange rate and Lcy amount tags are manda­tory.
No
BLOCKRELEASES­TATUS
Block release status to be set as F - Full debit; P – For partial debit (Only if partial release is allowed).
Yes
TRN_DT
Transaction date on which accounting to be posted. It’s a non mandatory field, if not provided, accounting would be posted to current system date.
No
VALUE_DT
Value date on which accounting to be posted. It’s a non mandatory field, if not provided, would be defaulted to current system date.
No
TXNNARRATIVE
Transaction narrative captured as part of request will be displayed in account statement.
No
The following values will be passed as part of accounting handoff for accounting posting:
Values
Description
Default value
Possible values
Mandatory
CHEQUE_MANDATORY
If debit to happen against an account based on the instru­ment no, then cheque mandatory to be Y.
N
Y / N
No
INSTRUMENTCODE
If cheque mandatory is Yes, then instru­ment code to be mandatory in the request. Based on that, the chq no would be updated to used in Flexcube system.
Null
Valid instru­ment number
No
AVAILBALREQD
If balance checked to happen as part of ECA debit, this flag to be Y.
Y
Y / N
No
AVLINFO
Balance will be updated immediately / move to uncollected balance (for credit transaction alone) based on the value provided.
I - Imme­diate
I - Imme­diate-
V - On value Date
No
INTRADAYRELEASE
If Available info is I and intraday release is Y, then funds will be in Uncollected, to be cleared on intra­day batch run.
N
Y / N
No
ESCROW
If Escrow is set as Y, then on EAC credit, amount would be blocked, if it’s against a project account.
N
Y / N
No
CONSFORACCACTIVITY
To make the account undormant on ECA processing, then consider for account activity to be sent as Y in request.
Y
Y / N
No
CONSFORTRNOVER
To restrict the maxi­mum amount to be credited to an account, this flag to be sent as Y in the request.
N
Y / N
No
SWEEPREQD
If ECA debit is made more than requested amount and if sweep is Yes, then excess debit will be covered from cover accounts, if available balance isn't sufficient to cover excess debit.
N
Y / N
No
DEBIT_OVER­RIDE_TRACKING
If account is set for Debit override, if this tag has value B / O, then debit override will be displayed.
B
B/O
No
CREDIT_OVER­RIDE_TRACKING
If account is set for Credit override, if this tag has value B / O, then credit override will be displayed.
B
B/O
No
DONTSHOWINSTMT
If during reversal request of external entries, reversal entries to be excluded from account statement, then DONTSHOW­INSTMT should be Y.
N
Y/N
No
EVENTSRNOTOBEREVD
If during reversal request of external entries, event slr no to be reversed should be sent in request.
Null
Valid event slr no
Yes (for reversal request)
TRNCODE
If transaction code is sent as part of request, it will be stored in the ACT­B_ENTRIES_TRN­CODE_DETAILS table
Null
Transac­tion Code
No
SWIFT_CODE
If SWIFT_CODE is sent as part of request, then it will be displayed in the SWIFT account statement.
Null
Valid SWIFT code
No
Note
Transaction code is not mandatory for external entry hand-off.
