| Siebel CRM Assignment Manager Administration Guide Siebel Innovation Pack 2017, Rev. A E24725-01 |
![]() Previous |
![]() Next |
View PDF |
Running Siebel Assignment Manager in interactive mode allows end users to make real-time assignments. End users can review a list of potential assignees generated by Assignment Manager, then select and confirm, or override the assignment from the generated potential candidate list. For example, a call center agent might review potential candidates for an activity, then based on the candidates' assignment scores, expertise, or workload, assign the best candidate for the job.
The Activity and Service Request assignment objects are predefined to use interactive assignment, which allows you to assign employees to activities and service requests in real time. However, you can configure other assignment objects to use interactive assignment.
For information about how to configure assignment objects to use interactive assignment, see "Configuring Assignment Objects for Interactive Assignment".
You can run interactive assignment using any of the following:
Siebel Web Client (also known as zero-footprint client)
Command-line Server Manager (srvrmgr) program
Siebel Developer Web Client
Siebel Mobile Web Client users running Assignment Manager in interactive mode do not make real-time assignments, because any interactive assignments made by mobile users are not applied to the server until these users resynchronize.
The requirements for interactive assignment are that the:
Assignment Manager component is Online
Server Request Broker component is Running
This topic is part of "Running Interactive Assignment".
To run interactive assignment from the GUI
Navigate to either of the following locations:
Activities screen, then Activity List, and then the All Activities view
Service Requests screen, and then the All Service Requests view
In the All Activities or All Service Requests list, select an open activity or service request for assignment.
In the form, click the Menu button and select Assign to start interactive assignment.
For an example, see Figure 6-3.
Choose an assignee from the list of best candidates provided by Assignment Manager.
The Siebel application then:
Communicates with the Siebel Assignment Manager on the Siebel Server and creates a list of qualified employees for the activity or service request.
Displays the list of qualified employees to the Siebel user, sorted by the descending order of scores.
Sets the activity or service request owner to the employee that is chosen when clicking the Assign button.
This topic gives one example of running interactive assignment from the graphical user interface (GUI). The example is applicable for use with the Siebel Web Client or the Siebel Developer Web Client. You might use this feature differently, depending on your business model.
To run interactive assignment for a service request
Navigate to the Service Requests screen, and then the All Service Requests view.
In the All Service Requests list, select an open service request for assignment.
Communicates with the Siebel Assignment Manager on the Siebel Server and creates a list of qualified employees for the service request.
Sets the service request owner to the employee that you choose.
By default, interactive assignment submits requests to a Siebel Assignment Manager component that is running in default mode. However, you can use the Assignment Manager component (AsgnSrvr) to run interactive assignment in rule group mode, with or without using server key mappings.
Use server key mappings when you want to split your rules across different servers. You can explicitly define what rule groups to load on what server, and only rules from that particular rule group are executed. At the time of the assignment request, you can specify one of the rule groups as the Assignment Key parameter (AsgnKey) along with the request.
If you use server key mappings, then, when you click the Assign button, a request is sent to the Assignment Manager component to evaluate and return the qualified candidates. To submit requests to a server that has server key mappings, one of the rule group IDs must pass because the AsgnKey parameter must pass. To accomplish this, the SetAsgnKey method is called on the CSSBCBase business component base class. Using a script, a workflow process, or a business service, this method is called and the row ID of one of the rule groups is passed as the parameter.
After this is complete, interactive assignment uses this parameter value as the AsgnKey and ReqKey parameters when submitting requests to the Assignment Manager component. Note that, for one session, you only need to call this method once. Subsequent requests in the same session reuse the rule group row ID. However, when the session is logged out or the server is restarted, you must call this method again to set the AsgnKey parameter. Otherwise, the Assignment Manager reverts to running in default mode.
The following procedure summarizes the steps involved in running interactive assignment using server key mappings.
To run interactive assignment using server key mappings
Use the SetAsgnKey method to set the AsgnKey argument to the row ID of the rule group that you want to use.
Add the rule group record to the Server Key Mappings view.
Add the BusComp user property to the business component being assigned interactively, and set the value of Use Assignment Request Key to TRUE.
Assignment Manager supports the use of rule group mode even if you do not want to split your rules across multiple servers. In this case, you do not create server key mappings. Instead, you submit the request by specifying the rule group in the AsgnKey parameter for Assignment Manager. Even if there are no server key mappings, each Assignment Manager process loads all active rules. Assignment Manager determines at request time whether to execute all rules or only rules from a particular group, based on whether or not the assignment key is passed.
The following procedure summarizes the steps involved in running interactive assignment without using server key mappings.
To run interactive assignment without using server key mappings
