| Siebel CRM Siebel Mobile Guide: Connected Siebel Innovation Pack 2017, Rev. A E52426-01 |
![]() Previous |
![]() Next |
View PDF |
The following procedure shows you how to reset the host server for an application using the Siebel app on iOS or Android devices. When you reset the host server, all applications configured on the host server are reset.
To reset the host server using the Siebel app
Start your iOS or Android device and then tap Siebel to start the Siebel app.
Tap Reset All, and then tap Yes when prompted with the following message:
Application Data will be reset. This will take effect when the application is restarted.
The next time you start the Siebel app, the connection field or host server address field will be empty. For more information about connecting to the host server, see "Configuring the Siebel App on iOS and Android Devices"
