| Siebel CRM Siebel Mobile Guide: Connected Siebel Innovation Pack 2017, Rev. A E52426-01 |
![]() Previous |
![]() Next |
View PDF |
Barcode scanning is supported by default for activity parts in the Siebel Mobile application for Siebel Field Service. To use the barcode feature in a different application view, then you must set up the barcode interface for the view in question. To use the barcode feature in a different mobile application (for example, the Siebel Mobile application for Siebel Pharma), then you must set up the barcode interface for a view in the required mobile application. For more information about setting up the barcode interface, which is an administrator task, see the chapter about barcodes in Siebel Field Service Guide.
The barcode interface in the Siebel Mobile application for Siebel Field Service allows you to scan barcodes for parts using a barcode reader. For more information, see "Modifying Part Tracker for an Activity by Scanning Barcode Data".
You can also search for records by scanning barcode data in the Siebel Mobile application for Siebel Field Service. For more information, see "Searching for Records by Scanning Barcode Data".
You can use a barcode reader to search for records in the Siebel Mobile application for Siebel Field Service by scanning barcode data. For example, the following procedure shows you how to search for a service request by scanning the service request number. For more information about the barcode functionality in Siebel Mobile, see "Scanning Barcodes in Siebel Mobile".
To search for records by scanning barcode data
Select QuickSearch in the search toolbar on the application banner.
In the Barcode drop-down list, select Asset#.
A text box field appears.
Scan the barcode (in this example, the asset number).
A query is performed and results are returned in the view containing the record with the Asset# data.
