| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2017, Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
Siebel Mobile uses Siebel Open UI. Before you can use Siebel Mobile, you must meet the following requirements:
You must have a mobile device with an internet connection.
The browser on your mobile device must support the following: HTML5, CSS 3.0 or higher, and JavaScript 1.5 or higher.
If running your Siebel Mobile disconnected application (in offline mode) in a browser session, then you must have a minimum of 50 megabytes (MB) of available storage on your mobile device.
You have reviewed the topics about Siebel and Siebel Mobile in the applicable Siebel Installation Guide for the operating system you are using.
