| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2017, Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
An activity is a task that you perform for a contact, account, or opportunity.
The following procedures related to activities and activity management are included in this topic:
"Modifying Employee Information for an Activity"
Note: You must complete the relevant setup tasks detailed in Siebel Applications Administration Guide before using the Siebel Mobile application for Siebel Sales. |
You can display activity details by using the Activities list.
To display activity details
Tap Side Menu and then tap Activities to display the following:
The Activities list and details for the selected activity in the main pane.
A list in the side pane in which you can select the related items for activities.
Tap an activity in the Activities list.
All details for the selected activity appear after the list in the main pane.
To view the related items for the selected activity, tap the following names in the list in the side pane:
Contacts. Shows the contact information for the activity. For more information, see "Modifying Contact Information for an Activity".
Employees. Shows the employee information for the activity. For more information, see"Modifying Employee Information for an Activity".
Complete the following procedure to modify activity information.
To modify activity information
Update an existing activity as follows:
Tap the record field that you want to update, and update the field value.
You must navigate away from the record to save your changes to it.
Create a new activity as follows:
Tap New (the plus (+) icon) in the main pane.
Enter the information for the new activity in the fields that appear, and then save the record.
Complete the following procedure to modify the contact information for an activity.
To modify the contact information for an activity
Update an existing activity contact as follows:
Tap Contacts in the list in the side pane.
All contacts associated with the activity appear in the Contacts list in the main pane.
Tap the contact that you want to update.
Add an existing contact to the activity as follows:
Tap Contacts in the list in the side pane and then tap Add (the plus (+) icon) in the main pane.
Choose the contact on the list that appears, and then tap the OK.
Note: You cannot directly create new activity contacts using the double plus (++) icon in offline mode. In the case of child views where records are being associated, associating a downloaded contact with a selected activity using the plus (+) icon is supported in offline mode. |
Complete the following procedure to modify the employee information for an activity.
To modify the employee information for an activity
Update an existing activity employee as follows:
Tap Employees in the list in the side pane.
All employees associated with the activity appear in the Employees list in the main pane.
Tap the employee that you want to update.
Add an existing employee to the activity as follows:
Tap Employees in the list in the side pane and then tap Add (the plus (+) icon) in the main pane.
Choose the employee on the list that appears, and then tap OK.
