| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2017, Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
You can copy and delete duplicate copies of mobile applications in Siebel CRM as shown in the following procedure. You should not delete any Siebel-provided applications. Note the following:
When you copy a mobile application, the application plus all the associated child business component records are copied.
When you delete a Siebel Mobile disconnected application, the application plus all the associated child business component records are deleted.
Before deleting a mobile application, it is recommended that you make a copy of it first.
Note: The Deep Copy and Deep Delete user properties are used to copy or delete records in Siebel Mobile. For more information about using Deep Copy and Deep Delete to copy and delete records in child business components, see Siebel Developer's Reference. |
To copy and delete mobile applications in Siebel CRM
Log in to the Siebel Server using a user ID with a Siebel administrator responsibility.
Navigate to the Administration - Siebel Mobile screen, then the Application Administration view.
Create a copy of an existing mobile application as follows:
Select an application from the upper applet. For example:
Siebel ePharma Mobile (ENU)
Select Copy Record in the menu.
A duplicate record is created for the mobile application with the same Name and Language Code.
In the Language Code field, select a different language code.
Verify that the copy was successful by checking the records in the following child applets: Object Definition, Modification Tracking, Business Component Filters, Business Object Filters, and Settings.
Delete a duplicate or a copy of a mobile application as follows, but do not delete any Siebel-provided applications:
Siebel ePharma Mobile (ITA)
Select Delete Record in the menu, and then OK when prompted for confirmation to delete the selected mobile application record.
The record is deleted from the list of mobile applications.
