| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2017, Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
You administer server components for your mobile application from the Administration - Mobile screen, Server Component Administration view. The Server Component Administration view enables you to manage server-level settings for synchronization components. These settings are used by the synchronization engine to extract application definition and user data. These settings override the application-level settings at the component level on a specific server. The data entered here is used by the synchronization engine when the user synchronizes with the Siebel Server.
The server-component settings are used primarily for the functionality that is required for individual server components. For example, thread throttling depends on the components running on a particular server and is best set at the Siebel Mobile disconnected application server component level. Examples of settings that might be made at the component level are: MaxTotalThreadLoads, TranProcThreadLoad, DBExtractThreadLoad, and so on. Generally, the settings made at the application level are shared by all server components.
The following procedure shows how to configure component-level settings for mobile applications. This task is a step in "Roadmap for Setting Up Siebel Mobile Disconnected Applications".
To configure component-level settings for Siebel Mobile disconnected applications
Navigate to the Administration - Mobile screen, then the Server Component Administration view.
This view shows a list of server components associated with the application that is selected in the Siebel Mobile Setup view.
For each server component listed, do the following:
Make sure that the Name field value matches the exact component name, such as ePharmaMObjMgr_enu, of the synchronization server component for the Siebel Mobile disconnected application.
In the lower Settings applet, review or update the associated settings as required.
