| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2017, Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Roadmap for Setting Up Siebel Mobile Disconnected Applications". The Siebel Server installer copies the necessary DLLs to create a Siebel Application Object Manager for enabling server synchronization for Siebel Mobile disconnected applications. It also creates and configures a server component and component group. This topic describes which options you must select to install the software correctly, along with creating or configuring additional Siebel Application Object Managers.
This topic includes the following information:
"Configuring Logging Levels for Siebel Mobile Disconnected Application Synchronization"
"Roadmap for Configuring Incremental Synchronization for Siebel Mobile Disconnected Applications"
To set the logging level, you must perform the following tasks:
"Configuring Siebel Server Logging Using the Server Manager"
"Configuring Siebel Server Logging Using the Server Configuration Screen"
You set the logging level to a value between 1 and 5 as shown in Table 6-2.
Table 6-2 Logging Levels for Siebel Mobile Disconnected Application Synchronization
| Logging Level | Results |
1 |
Error listing |
2 |
Warning listing |
3 |
Information listing, including SQL tracing |
4 |
Information listing |
5 |
Debug information |
The following procedure shows you how to configure Siebel Server logging levels using the Server Manager.
To configure Siebel Server logging levels
Log in to the command Server Manager from a prompt.
Run the following command:
change evtloglvl HandheldSyncLog=[LogLevel] for comp [OMName], where [LogLevel] = an integer between 1 - 5 /*(5 enables all logging)*/ and [OMName] = the OM name /*(for example,<ApplicationName>ePharmaMObjMgr_enu)*/
The following procedure shows you how to configure Siebel Server logging levels using the Server Configuration screen.
To configure Siebel Server logging using the Server Configuration screen
Navigate to Administration - Server Configuration screen, then the Servers view.
Select the appropriate Siebel Server in the upper applet.
In the Components applet, query for the appropriate component.
Select the Events tab and then do the following:
Query for the event type, Handheld Sync Logging.
Set the value to a number between 1-5, and then save the change.
See Table 6-2 for the logging-level results.
Several parameters help to optimize Siebel Server processing for Siebel Mobile disconnected application synchronization.
To set parameters to optimize Siebel Server process management
Log in to the Siebel application as a user with administrator privileges.
Navigate to the Administration - Server Configuration screen, then the Servers view.
For example: ePharmaMObjMgr_enu.
Select the Parameters tab and then update the parameters as described in the following table.
| Parameter | Description |
| Max Tasks | Determines the maximum number of threads that can run concurrently for a given component. Set the value of this parameter to a number equal to that of the expected peak number of concurrent synchronizations for each Siebel Server. |
| Min MT Servers | Determines how many multithreaded server processes are started by default for the Siebel Application Object Manager. |
| Max MT Servers | Defines the maximum number of processes supported by the instance of Siebel Application Object Manager. The value for this parameter must be the same as the Min MT Servers parameter. Set it so that the threads for each process (Max Tasks and Max MT Servers) are optimized. |
