| Siebel CRM Partner Relationship Management Administration Guide Siebel Innovation Pack 2017, Rev. A E24800-01 |
![]() Previous |
![]() Next |
View PDF |
When a deal registration is submitted, it is available for approval by the vendor.
To approve a deal registration
Navigate to the Administration - Inbox screen, then the All Submitted Items view.
A deal registration that requires approval is displayed in the inbox of the current approver.
Drill down on the deal registration.
Check if there are potential duplicates by navigating to the Similar Registrations view.
Note: Opportunities identified as potential duplicates must share the same end customer and have at least one product in common. |
Approve, reject or return the deal registration.
If and when the final approver approves, the status of the deal registration changes to Approved.
Only one deal registration can be approved for each opportunity. If other deal registrations are submitted for the same opportunity, they appear in the registrations list, but you cannot approve them until the current approved registration expires.
