Siebel Product Administration Guide > Siebel Configurator UI Properties > About Siebel Configurator UI PropertiesA UI property is a named variable and its value. UI properties modify the display of an item in Siebel Configurator. You define a UI property by selecting the desired item and then defining one or more UI properties for it. There are two types of UI properties:
The Properties view displays all the items in the customizable product: To use the Properties view, you select an item in the customizable product and then define a UI property for the item in Item Display Properties. Each record in Display Properties has two fields. The first contains the name of the UI Property variable. The second field contains the value you want to assign to the variable. This value is what displays in the configuration session. Observe the following guidelines when defining UI properties:
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
