Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Product Administration Guide > Siebel Configurator UI Properties > Defining a UI PropertyA UI property is a named variable and its value. UI properties modify the display of an item in a customizable product. You define a UI property by selecting the desired item in a customizable product and then defining one or more UI properties for it. If you are using an attribute from a line item integration component field to define the UI property, see Binding an Attribute Value to a Line Item Integration Component Field. To define a UI property for a product
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
