Siebel Product Administration Guide > Siebel Configurator UI Properties > Creating Dynamic Siebel Configurator User Interface Controls > Example of Dynamically Showing and Hiding Siebel Configurator ControlsThis topic gives one example of dynamic show and hide. You might use this feature differently, depending on your business model. This topic shows how to create the example described earlier. A business sells tee-shirts that can be personalized with the name and business name of the purchaser or that can be bought without personalization. The root product is a tee-shirt with attributes including the following: Personalize and Name. If the user selects the Personalize checkbox (which sets the Personalize attribute to Y), then an additional Siebel Configurator tab is displayed that allows the user to enter the customer's name and the business name. This example assumes that you have defined the product and have defined the Siebel Configurator UI, including the tab used for personalization. The requirement is that you use the dynamic show and hide feature to hide the Name attribute when the Personalize checkbox is not selected (so the Personalize attribute is N). To dynamically show and hide a Siebel Configurator control
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
