Siebel Product Administration Guide > Basic Product Administration >
Comparing Features of Equivalent Products
You compare equivalent products by displaying all the equivalent products for a product and then selecting which features you want to use for the comparison. You can then rank the equivalent products. To compare features of equivalent products
- Navigate to the Administration - Product screen, then the Products view.
- In the Products list, select the desired product.
- Click the Collateral view tab.
- In the Collateral view link bar, click Key Features.
The Product Comparison list appears beside the Key Features list. Equivalent products are displayed in the columns of the Product Comparison list.
- In the Product Comparison list, add a new record.
A dialog appears that contains all the product feature definitions.
- Select the desired product from the dialog box.
The feature is added to the Product Comparison list.
- Repeat these steps until all the desired features have been added.
- Assign a ranking to the equivalent products, if desired.
A rank of 1 means a product has the highest degree of equivalence relative to the other equivalent products.
