Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs to Set Product and Attribute Values > RepriceInstance MethodThis method updates the instance with values from the Pricing Manager service. A call to the Pricing Manager service's CalculatePriceCX method returns a property set that is the input to this method. Input Arguments
The input property set has child property sets containing the repricing information. The format of the input property set is as follows: < ObjId="value" RootId="value" Version="value" > < IntId="integration id" FieldName="value"... FieldName="value" > < IntId="integration id" FieldName="value"... FieldName="value" > In this context, the Integration ID is used to retrieve the instance item. Output Arguments |
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
