Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Product Administration Guide > Releasing Products and Other Versioned Objects > Displaying Product Versions that Are Available to CustomersWhen you replace earlier versions of a product, you create version records that are never visible to customers because their start date and end date are the same. In the Versions list, you can use the Time Filter button to filter out versions that have been replaced and view only versions that will be visible to customers. This button is a toggle. After you have used it to hide versions that have been replaced, click it again to display all versions. To display only product versions that are visible to customers
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
