Siebel Product Administration Guide > Configuration Constraints > Process of Setting Up Advanced Constraint Configurator >
Setting Up Advanced Constraint Configurator System Preferences
Perform the steps in the following procedure to update up the Advanced Constraint Configurator system preferences. To set up Advanced Constraint Configurator system preferences
- Log in to a Siebel application on the Siebel Server.
- Navigate to Administration - Application, and then the System Preferences view.
- In the System Preferences list, either query for the following system preferences, or create the system preferences if they do not already exist, then enter the values shown in the following table:
ConstraintEngineHost |
<host>:<TLS-port> |
Specifies the host and TLS port numbers where the constraint engine is deployed to access the Advanced Constraint Configurator. NOTE: This applies only to products using Oracle's Advanced Constraint Configurator.
EnableOraCfgEngine |
N/Y |
Enables the Advanced Constraint Configurator at the enterprise level. This value is overridden by the UI property found at the Customizable ProductThe default value for this system preference is N. |
