Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Product Administration Guide > Configuration Constraint Template Reference > Constrain Resource Value TemplateThe Constrain Resource Value template has the form: The template has three parts. The first operand names the resource. The operator, [>], defines how the resource is related to the second operand, [a value]. The operator is limited to numeric comparisons (=, <, >, and so on). The [a value] operand can be any of the following:
The "Insert a" tab provides two sets of arithmetic functions that allow you to combine these items into expressions. Use the Constrain Resource Value template to define limits on the value of a resource. For example, you can constrain a resource to be greater than 0 and less than 5. |
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
