Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Product Administration Guide > Siebel Configurator Scripts > Siebel Configurator Script Events and Methods > GetAttribute MethodThe GetAttribute method gets the value of an attribute for an item in the customizable product. This method can also be used to get attribute values for attributes of the customizable product. If multiple instances of an item have the same path, the Siebel Configurator engine randomly picks one instance. Users can reference a particular instance of a product by using $Int.[<id>] to specify the integration id in the product path. SyntaxGetAttribute (ObjPath, AttName) as String Input ArgumentsOutputThis API returns a string. If it is successful, the string contains the Language Independent Code (LIC) value of the attribute. If it is not successful, the string is empty. ExamplesPtype = GetAttribute("$.[Life Insurance]#1", "PlanType") AttVal = GetAttribute("$.[RootProd1]#1.[Rel1]#[ChildProd1]", "attr1"); |
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
