Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Product Administration Guide > Smart Part Numbers for Products with Attributes > Process of Creating Dynamically Generated Smart Part Numbers > Testing the Part Number TemplatesFinally, test the part number template. This task is a step in Process of Creating Dynamically Generated Smart Part Numbers. You do this by creating a quote and selecting the product for which you have created a smart part number method. Add the product to the quote enough times so that you can select all the combinations of attributes needed to verify that the smart part number template is working correctly. The smart part number displays in the Line Item Detail view. For more information on locating the smart part number in a quote, see Viewing a Product's Smart Part Number in a Quote. |
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
