Siebel Product Administration Guide > Siebel Configurator Technical Reference >
Configuring the Object Broker
If you modify the assignment of Cfg UI Field properties on the fields of the Cfg ISS Prod Def business component, you must do the following:
- After you make the changes, manually clean the file system's ISS_OBrkCache folder, as described in Delete Contents of ISS_OBrkCache Directory.
- Run all installations of Siebel applications that use the same file system from the runtime repository where you made the changes.
