| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2017, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
Using the Siebel Management Console to change an anonymous user password automatically saves the password in encrypted form.
Although the anonymous user has limited privileges, it is generally recommended to use more secure passwords for production deployments of your Siebel Business Applications. For anonymous user accounts, changing passwords involves changing passwords for database accounts and changing passwords in the Siebel Application Interface profile.
Note: If you want to use different database accounts for the anonymous user for different applications, then you must manually update the Siebel Application Interface profile. |
The following procedure describes how to change an encrypted password using the Siebel Management Console.
To change encrypted passwords using the Siebel Management Console
Log in to the Siebel Management Console.
Click Profiles in the navigation menu, and then click Application Interface.
Existing application interface profiles are listed, if any.
Select the application interface profile that you want to modify, and then click Edit.
Go to the Basic Information section, click Authentication and change the Anonymous User Password.
To change the anonymous password specific to other applications (such as Siebel Call Center, EAI, or REST API), then do the following:
Go to the Applications section, and select the check box next to the application you want to modify.
Click Authentication, and change the Anonymous User Password as required.
