| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2017, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
If you are using RSA encryption for communications between Mobile Web Clients and the Siebel Remote Server, then the following steps explain how Siebel encryption keys are exchanged between the client and the server:
The client generates a private/public key pair. The public key is sent as part of the Hello message to the remote server.
When the server receives a Hello message, it generates an AES-based symmetrical session key and encrypts the symmetrical session key using the client's public key from the Hello message. The encrypted session key is sent back to the client as part of the Hello Acknowledge message.
The client uses its private key to decrypt the server-generated session key. From this point on, both the client and the server use the server-generated session key to encrypt and decrypt messages.
The session key is good for the lifetime of the connection.
If you are using TLS encryption between the Web server (Siebel Application Interface) and Siebel Server or between Siebel Servers, then the key exchange is handled through a standard TLS handshake.
