| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2017, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
One Employee record is provided as seed data at installation, as described in Table B-1. This record does not have a database login or a responsibility, but, like other employees, it does have a position and an organization. The PROXYE user record is not installed with a default password.
Customer users, such as Siebel eService users, are not assigned their own position or organization. When a customer user logs in, the application programmatically associates the proxy employee with the user. The proxy employee provides the following functions:
Data subsequently created by the user is associated with the organization of the proxy employee, which allows the data to display in views that implement organization access control.
The user can see data created by the user and by others in views that implement organization access control.
The proxy employee is specified at the application level as a parameter on the Siebel Gateway. For information about organization access control, see "Access Control Mechanisms".
