| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2017, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
Secure login is enabled when Siebel Web Client is configured and accessible over HTTPS. The Siebel installer enforces HTTPS for Web server access. For more information, see the topic about installing Siebel Business applications in Siebel Installation Guide for the operating system you are using.
With secure login, the Siebel Web application server transmits user credentials entered in a login form from the browser to the Web server using TLS, that is, over HTTPS.
Note: You cannot log into a Siebel application by presenting user credentials as parameters in a URL. |
For information about administering Siebel Server components, see Siebel System Administration Guide.
