| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2017, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
This topic describes problems related to either enabling or disabling certain secure parameter settings. To resolve the problem, look for it in the list of Symptoms or Error messages in Table 10-4.
Table 10-4 Troubleshooting Secure Parameter Settings
| Parameter Setting | Symptom or Error Message | Diagnostic Steps or Cause | Solution |
Enable XSS Filter |
The Siebel application freezes when a user selects the OK button on a Siebel screen. |
Make sure that Enable XSS Filter is set to Y. |
Do not disable the Enable XSS Filter setting. |
