| Siebel CRM System Administration Guide Siebel Innovation Pack 2017 E24823-01 |
![]() Previous |
![]() Next |
View PDF |
Table B-2 contains an alphabetical listing of some of the configuration parameters from Siebel application configuration files such as siebel.cfg or uagent.cfg. This list shows the name of the section in which each parameter can be found and identifies where the parameter is documented (within Table B-3 and Table B-5). This list is not comprehensive.
Table B-2 Index of Configuration Parameters
| Configuration Parameter Name | Section Name | Where Documented and Description |
AccessDir |
AllowAnonUsers |
Siebel Security Guide |
ApplicationName |
ApplicationPassword |
Applicable security adapter sections, such as:
ApplicationSplashText |
ApplicationTitle |
ApplicationUser |
Applicable security adapter sections |
BaseDN |
CancelQueryTimeOut |
Siebel Applications Administration Guide |
CaptionPrefix |
CaseInsensitive |
Applicable data source sections, including:
ClientRootDir |
CommConfigCache |
Siebel CTI Administration Guide |
CommConfigManager |
CommConfigManagerName |
CommEnable |
CommLocalDriver |
CommLogDebug |
CommLogFile |
CommMaxLogKB |
CommMaxMsgQ |
CommReleaseLogHandle |
CommReqTimeout |
ComponentName |
ConnectString |
"ConnectString" (data sources) |
ContactLogin |
Applicable data source sections |
CredentialsAttributeType |
DataSource |
DebugLevel |
Siebel Email Administration Guide |
DefaultMailClient |
DisableExecuteRetry |
DisableReverseProxy |
DLL |
Docked |
DockConnString |
DockRecvTxnsPerCommit |
DockRepositoryName |
DockTxnsPerCommit |
EditFieldCaption |
Configuring Siebel Business Applications |
EditFieldType |
Enable |
Siebel Data Quality Administration Guide |
EnableFQDN |
Siebel Installation Guide for the operating system you are using |
EnableInlineForList |
If the applet mode property is set to Edit List, then the functions Edit, New, and Query work in-line, that is, in the list applet, when EnableInlineForList is set to True. The default value is True. Set to False to turn off this behavior. |
EnablePersonalization |
EnableScripting |
EnterpriseServer |
eProdCfgNumbOfCachedCatalogs |
Siebel Performance Tuning Guide |
eProdCfgNumOfCachedObjects |
eProdCfgNumbofCachedWorkers |
eProdCfgSnapshotFlg |
FileSystem |
FQDN |
GatewayAddress |
GatewayDataSrc |
Hidden |
InsensitivityFactor |
InsUpdAllCols |
IntegratedSecurity |
Local |
LocalDbODBCDataSource |
LoginView |
MaxCachedCursors |
MaxCachedDataSets |
MaxConnections |
MaxCursorSize |
MaxDepthOfTheQuery |
MessageBarUpdateInterval |
MultiCurrency |
NonSQL |
NumberOfListRows |
Siebel Object Types Reference |
PasswordAttributeType |
PersonalizationLog |
Port |
PrefetchSize |
PrimaryEnterprise |
RemoteSearchServer |
RemoteSearchServerPath |
ReportDataDir |
Siebel Reports Guide |
ReportsDir |
ReportOutputDir |
ReportsODBCDataSource |
RepositoryFile |
RequestServerName |
This parameter is the name of the Siebel Server that services requests from the Siebel client. |
RequiredIndicator |
Siebel Developer's Reference |
ReverseFillThreshold |
RolesAttributeType |
Sample |
ScriptingDLL |
SearchDefName |
SearchEngine |
SearchInstallDir |
SecAdptDllName |
SecAdptMode |
SecAdptName |
ServerDataSrc |
ServerName |
SharedCredentialsDN |
SharedModeUsersDir |
ShowMessageBar |
ShowWriteRecord |
Siebel Partner Relationship Management Administration Guide |
SiebelExtMailClientAttDir |
SiebelUsernameAttributeType |
SingleSignOn |
SqlStyle |
SslDatabase |
SystemSWFName |
SystemSWSName |
TableOwner |
TempDir |
TreeNodeX (several parameters that are similarly named, for example, TreeNodeCollapseCaption) |
TrustToken |
Type |
UpperCaseLogin |
UseDictionaryinTransaction Logging |
UseAdapterUsername |
UseRemoteConfig |
UserSWFName |
UserSWSName |
Version |
WebTemplatesVersion |
XdoDir |
