| Siebel CRM System Administration Guide Siebel Innovation Pack 2017 E24823-01 |
![]() Previous |
![]() Next |
View PDF |
This topic describes how to configure the environment for your Application Object Manager components.
To configure the Application Object Manager environment
Make sure that Application Object Managers are included as part of the Siebel Server installations you plan to use.
Configuring a Siebel Server defines the Application Object Manager components for this Siebel Server. For information about installing and initially configuring the Siebel Server, see the Siebel Installation Guide for the operating system you are using.
Verify that the customized Siebel runtime repository is included in the Siebel database that serves the modified application.
It is strongly recommended that no other user besides the application developer customize the Siebel runtime repository.
Configure the Application Object Manager components by setting the parameters that control:
Application name to run (configuration file)
Language code
Compression setting
Encryption setting
Number of processes for each component
Number of threads or tasks for each process
Session Manager parameters
For more information about this topic, see "About Application Object Manager Parameters".
Restart the Siebel Server system service to automatically register the Application Object Manager services (configured in Step 3).
