Testing Siebel Business Applications > Usage Pattern Tracking and Conversion to Keyword Scripts > Importing the Test ScriptsYou can import the generated scripts into the database from the Script pane or from the Release Screen. To import the test scripts from Script Pane to Database
You can choose to select a single script or multiple scripts to import them into the database. A pop up message is displayed with the the number of scripts that were imported successfully and the scripts that were not imported successfully. NOTE: The import process will fail when you try to import a script with the same name if it is already available in the database. The log details of a failed import process will be available in the Siebel Logs folder. To export and import the test scripts from Release Screen
The test script is downloaded in the download folder in the xml format. You can use this xml file to import a test script into the database.
The script will be imported into the database. If you have a script with the same name in the database, it will be replaced with the existing script. In this way the scripts can be exported and imported to different environments. |
| Testing Siebel Business Applications | Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
