Siebel Database Upgrade Guide for DB2 for z/OS > Running the Database Configuration Wizard to Perform Upgrade Tasks > Inactivating Unreferenced Repository ObjectsThe Inactivating Unreferenced Repository Objects Utility identifies the unreferenced objects in the database and deactivates the unreferenced objects. Inactivating Unreferenced Repository Objects Utility finds unreferenced objects for the following Siebel objects:
The Inactivating Unreferenced Repository Objects Utility runs as part of the upgrade process. Use the procedures in this topic to manually run the Inactivating Unreferenced Repository Objects Utility. Running the Inactivating Unreferenced Repository Objects Utility
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
