Siebel Database Upgrade Guide for DB2 for z/OS > Preparing Data for a Siebel Migration > Process of Transforming Data with Siebel Application Deployment Manager >
Creating an ADM Data Map
This topic provides procedures for creating an ADM Data Map. This task is a step in Process of Preparing Siebel Application Data for Migration. To create an ADM data map
- Navigate to the Site Map, Administration - Integration, and then Data Map Editor.
- In the Data Map Editor applet, create a new record.
- Enter a Name for the data map.
- Choose the Integration Object that is used in the Data Type for both the Source Object Name and the Target Object Name.
- Click Auto-Map to populate the Integration Component Map and Integration Field Map fields.
- In the Integration Component Map applet, select the Integration Component to transform the data.
- In the Integration Field Map applet, select the Field to transform the data.
- In the Source Expression column, enter the expression to transform the data. For more information about supported expressions, see Application Deployment Manager Guide.
- Click Save.
