Siebel Database Upgrade Guide for DB2 for z/OS > Preparing Data for a Siebel Migration >
Setting Up File Prepare and Deploy
Siebel Migration File Prepare and Deploy service does the following:
- Migrates file artifacts from the source environment to the target environment.
- Migrates only file artifacts from Siebel Application Interface (AI) and the Siebel File System.
- If the target environment has multiple Application Interface nodes, it migrates all file artifacts to all the Application Interface nodes.
- Supports incremental file Migration (migrates only new or modified files).
- Uses the Checksum utility to check whether the file is modified or not.
The list of directories considered for Migration are configured in the filemig_config.properties file. The filemig_config.properties file is located in the following directory: <Application Interface Home>\applicationcontainer\webapps
The filemig_config.properties file:
- Contains three properties:
- inclusion-dir
- exclude-dir
- exclude-extension
- Considers all the files from the list of directories provided in the inclusion-dir property.
- Ignores all the directories mentioned in the exclude-dir from the include-dir only.
- Ignores the files whose extensions are part of exclude-extension property
Sample filemig_config.properties file: inclusion-dir=%ORACLE_HOME%/applicationcontainer/webapps/siebel/files, %FS_HOME%/att exclude-dir=%ORACLE_HOME%/applicationcontainer/webapps/siebel/files/3rdParty exclude-extension=xps, pdf
Where:
- %ORACLE_HOME% is the AI installation directory.
- %FS_HOME% is the Siebel File System Path.
You can add multiple directories separated by a comma.
