Using Siebel Tools > Using Siebel Script Editors > Using the ST eScript Engine >
Enabling the ST eScript Engine
If you want to use the T eScript Engine, then you can disable the ST eScript Engine in Siebel Tools. If you disable the ST eScript Engine, you can enable it later. To enable the ST eScript Engine
- Open Siebel Tools.
- Click the Screens menu, System Administration, and then click System Preferences.
NOTE: In Web Tools, click the Tools menu and then click the System Preferences menu item.
- In the System Preferences list, set the Enable ST Script Engine system preference to one of the following values:
- TRUE. Enables the ST eScript Engine.
- FALSE. Disables the ST eScript Engine.
CAUTION: Disabling the ST eScript Engine is not recommended. For help with disabling this engine, create a service request (SR) on My Oracle Support. Alternatively, you can phone Global Customer Support directly to create a service request or get a status update on your current SR.
If you want to revert to the T eScript Engine after you use the ST eScript Engine, and if you use strongly typed code while you use the ST eScript Engine, then you must undo this strongly typed code before you revert to the T eScript Engine. For more information about setting system preferences, see Siebel Applications Administration Guide.
- Deliver your scripted objects.
For more information on how to deliver your workspaces, see Delivering Workspaces.
- To use the Siebel eScript Engine, exit Siebel Tools, and then reopen it.
Enabling the ST eScript Engine in the Siebel Application
If you enable the ST eScript Engine in the development environment, then make sure you also enable it in the Siebel application. You must use the same Siebel eScript Engine setting when you compile code in these environments, and you must use the same engine setting for these environments that you use to compile the code.
