Using Siebel Tools > Using Siebel Tools > Using Menus and Running Queries >
Using a Right-Click Menu
A right-click menu is a type of context-sensitive menu that appears if you right-click an object or an element. It allows you to do the following:
- Create, copy, or delete a record.
- Undo modifications that you make to a record.
- Display the name and status of a toolbar. You can right-click any toolbar. You can also customize how a toolbar appears.
- Check out or lock an object.
- Add an object to an archive.
- Access wizards.
NOTE: Right-click is available only in Siebel Tools.
