Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars > Using the Controls/Columns WindowThe Controls/Columns window is a window that displays the controls and list columns that you can add to an applet layout if you use the Applet Layout Editor. Click a control or list column in the Controls/Columns window, and with the mouse button depressed, move it to a placeholder in the Applet Layout Editor and then release the mouse button. If you choose a control or a list column in the Controls/Columns window, then the Properties window displays the properties for the object that you choose. The Controls/Columns window includes the following items:
For an example that describes usage that is similar to usage for the Controls/Columns window, see Using the Applets Window. |
| Using Siebel Tools | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
