Using Siebel Tools > Using Web Tools >
About Delivering in Siebel Tools and Web Tools
In Siebel Tools, you deliver modifications to implement your configuration changes in the user interface of the Siebel application. You deliver the modifications that you make to objects directly into the Siebel application. To deliver modifications, see Delivering Workspaces. In Web Tools, you deliver modifications to implement your configuration changes in the user interface of the Siebel application. You deliver the modifications that you make to objects directly into the Siebel application.
