This document is designed to help acquaint you with the integration among Oracle FLEXCUBE products namely; Oracle FLEXCUBE Universal Banking Solutions (FCUBS) and Oracle Banking Corporate Lending (OBCL).
Besides this user manual, while maintaining the interface related details, you can invoke the context sensitive help available for each field. This help describes the purpose of each field within a screen. You can obtain this information by placing the cursor on the relevant field and pressing the <F1> key on the keyboard.
This manual is intended for the following User/User Roles:
Role |
Function |
Back office data entry Clerks |
Input functions for maintenance related to the interface |
Back office Managers/Officers |
Authorization functions |
End of day operators |
Processing during end of day/ beginning of day |
Implementation Partners |
Provide customization, configuration and implementation services |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized into the following chapters:
Chapter |
Description |
Chapter 1 |
Preface gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
Chapter 2 |
Oracle OBCL - FCUBS Integration explains the integration between Oracle FLEXCUBE Corporate Lending and Oracle FLEXCUBE Universal Banking systems. |
Chapter 3 |
Annexure provides the details of data exchange and further reference sources. |
Chapter 4 |
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
Abbreviation |
Description |
AC |
Accounting |
CASA |
Current and Savings Account |
DDA System |
System that holds the CASA account and balances |
EAC |
External Account Check |
ECA |
External Credit Approval |
EOD |
End Of Day |
FCUBS |
Oracle FLEXCUBE Universal Banking |
FCY |
Foreign Currency amount |
GL |
General Ledger |
JNDI |
Java Naming and Directory Interface |
LCY |
Local Currency amount |
OBCL |
Oracle Banking Corporate Lending |
OL |
Oracle Lending |
ROFC |
Rest of Oracle FLEXCUBE |
System |
Unless and otherwise specified, it shall always refer to Oracle FLEXCUBE Universal Banking Solutions system |
XML |
Extensible Markup Language |
This user manual may refer to all or some of the following icons.
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
Along with this user manual, you may also refer to the following related sources:
