2. OBCL-FCUBS Integration
The integration between OL and CASA enables banks to do the following:
- Auto Liquidation
- Manual Liquidation
- Auto Rollover
- Manual Rollover
2.1 Scope
This section describes the activities that take place in each system
and its impact on the other.
2.1.1 Integration Scope with FCUBS Co-deployed with OL
If FCUBS is co-deployed with OL, then API or dynamic call is used
to check the available balance.
2.1.2 Integration Scope without FCUBS Co-deployed with
OL
The following are the integration activities that take place in Oracle
Corporate Lending.
ECA Request for Auto Liquidation
- As part of loans batch process, amount due for liquidation for a
contract is sent to the DDA system for approval in advance. ECA_BATCH_DAYS
parameter maintained in cstb_param table. Only after receiving an approval
from the DDA system, the system proceeds with liquidation of the schedule.
- OL module should send a consolidate request to the ECA one for each
contract. As the settlement account is configured for each component
in Corporate Lending, multiple settlement accounts for a contract is
possible. OL module for a due date should group the total amount due
from each account and generate one ECA request for a contract and due
date.
- The due amount when sent as part of ECA request should be in account
currency.
- As part of the ECA request, OL module should send the following additional
preferences configured at a contract / product level.
- Partial Liquidation Allowed (PARTIAL_BLOCK_REQUIRED): If the flag
is set as ‘N’, then ECA system should send a fail approval
in case the total amount requested is not available in the account.
- In case of multiple schedules that are due from the customer as part
of Auto Liquidation, OL system should place a ECA request for the earliest
schedule due from the customer. Only when the schedule is completely
settled and processed in OL system, request for next schedule should
be placed.
- First process in OL batch would compute the amount due for a schedule
as part of Auto liquidation and place the request into ECA table with
the current status as ‘Pending’. A Java program would constantly
poll the table for any pending records and transform the records into
an ECA request XML and place the same into a IN queue of the external
system configured.
- Upon receipt of any response from the DDA system in the OUT queue
of OL module, the response would be parsed by the JAVA program and update
the status response status (Approved/Rejected) in COTBS_ECA_QUEUE table.
- When ECA block is successfully created on the accounts (Partial /
Full), liquidation happens in OL module and perform OL accounting with
handoff status as 'No'.
- ECA request for auto liquidation should not be created when future
dated payment is requested for the same contract.ECA request for auto
liquidation should not be created from OL module where GL is chosen as
settlement account. For example, for a contract having Principal and
Interest as components and GL is chosen as a settlement account then
no ECA request should be created by OL module. However, if GL is chosen
only for Interest and for Principal a valid customer account is chosen
as settlement account, then ECA request should be created only for Principal
component.
- When Auto Liquidation process is run for more than one day as part
of EOD processing (due to holiday settings), then Auto liquidation for
the schedules that are due for a day can be processed only after Auto
liquidation is processed successfully for the preceding day.
- In a situation where ECA block is successful, but subsequent processing
in OL module fails auto retry mechanism should be available in OL module.
ECA Handling during Auto Rollover
- For contract marked for Auto Rollover, as part of EOD processing
of Auto Liquidation system should place the ECA request for the liquidation
amount (or any special amount) that should be debited from the settlement
account of the customer.
- Upon receipt of successful response from the ECA system, subsequent
rollover processing should continue in the OL module.
ECA Handling for Manual liquidation
- After you capture the necessary payment details and click ‘Save’,
OL module should place an ECA request for the amount requested for the
payment.
- There should be an additional field in the payment screen to display
the ECA process status. This should display the status of the ECA request.
- When the ECA request is approved by the DDA system, it needs to be
manually authorized. Hence, manual payment is deleted for unauthorized
contract, an undo ECA should be sent to the DDA system.
- OL module should process the payment request and update the cashflow
tables and post liquidation entries as part of back ground process and
payment status will be in unauthorized state.
- Authorisation of payment is possible only after the liquidation process
is completed and entries are posted.
- Similarly OL module should generate reversal entries upon reversal
of loan payment. In case where actual accounting to DDA system is not
generated post ECA approval, OL module should generate both actual entries
for liquidation with block number and its reversal.
Actions
System Response
After logging payment in
ECA queue for approval, if you try to delete the payment before getting
the response, then the status is W.
The system should undo
ECA if it gets approved response (Reconcillation mechanism)
After getting ECA response
as ‘Approved’, if you try to delete the payment
ECA with the approved block number
ECA Handling for Manual Rollover
- After you initiate the rollover (Normal/Consol/Split) through application,
OL module should place an ECA request for the amount to be debited from
customer.
- When the ECA request is approved by the DDA system, the system allows
you to authorise the rollover. Hence, the rollover is deleted and undo
- In case where actual accounting to DDA system is not happened post
ECA approval, OL module should generate both actual entries for roll
event with block number to release from DDA system.
Account Interface and Handoff
- For CASA, where debit happened excluding force debit components,
have the block number in the daily log table.
- As part of accounting interface OL module should hold two handoff
status, one to indicate whether the customer account related entries
handoff to DDA system and another to indicate GL entries handoff to GL
system.
- External Account Check (EAC) is done wherever the credit happens
to CASA account to avoid failure in external system side (Check for No
credit, No debit,Frozen,Deceased)
- Java poller constantly polls the daily log table and pick the records
which are authorised and handoff yet to be done.It then generates the
accounting request with necessary details and put in IN queue.After getting
successful response from external system, handoff status is changed.If
anything failed while giving external handoff, external system throws
a proper exception code and same has been logged in OL side.
Debit request+ <ECAREFNO>
ECA Block is released
Debit request
Amount is debited from
withdrawable balance
- Credit and Debit advice should be generated only after the feedback
from the DDA system after posting entries to the customer account.
- OL module should be capable to handoff the entries online by generating
XML request as well as handoff entries through batch process at regular
intervals during the day.
Force debit Components
Tax, Fee and charge which are associated with liquidation/rollover
event is debited from the account without ECA.
2.2 ECA handling scenarios for Corporate
Loan Liquidation
2.2.1 Single CASA Account with Full
liquidation
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA1
10000
2.2.2 Different CASA Account with Full Liquidation
In this case OL module generates a single ECA request that contain
details amount due from two accounts.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA2
10000
2.2.3 GL Account used for Liquidation
In this case request is not sent to ECA system, however it is marked
as approved by OL module in ECA tables and it proceeds with liquidation
processing.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
GL1
50000
Interest
10000
GL2
10000
2.2.4 One CASA and GL Account used for Liquidation
In this ECA request is sent only for CASA account and the GL it is
marked as approved automatically. Liquidation processing happens irrespective
of whether the ECA request is successful for the CASA account.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA
50000
Interest
10000
GL1
10000
2.2.5 Single CASA Account with Partial Liquidation
In this case, the system proceeds with allocating the approved amount
based on liquidation order specified at the product level.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA1
10000
2.2.6 Manual Liquidation with Single CASA or Multiple
CASA Account
In this case ECA request is sent with Partial allowed as ‘N’,
hence the request is marked as failure if the full amount requested is
not available.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA1
10000
2.3 Prerequisites
2.3.1 Prerequisites in Oracle Banking Oracle Lending
The prerequisites for this integration are as follows.
2.3.1.1 Parameter Setup
- If HANDOFF_TYPE value is ‘SYNC’ in CSTB_PARAM table,
then the balance check is performed using API or dynamic call.
- If HANDOFF_TYPE value is ‘ASYNC’ in CSTB_PARAM table,
then the consolidated amount to be requested is logged in ECA tables.
Further processing, is performed by job.
- ECA_CHECK_REQD should be 'YES' in CSTB_PARAM table for standalone
system.
2.3.1.2 Maintenances
Complete the following maintenances in Oracle Banking Corporate Lending
to enable the integration.
Queue Name
Purpose
ECA_REQ_OUT
Request to external system
ECA_RES_IN
Response from external
system
Table Name
Purpose
COTB_ECA_QUEUE
ECA request details
COTB_ECA_QUEUE_DETAIL
ECA request components
details
Note
The following data in OL module must be in sync with
those maintained in external system.
- Branch
- Contract Reference Number
- Account number
- Currency
- Dr/Cr
2.4 Integration Process
2.4.1 Maintaining External System Details
In this screen external system name and description are maintained.
This information is used in the Queue Details (PIDECAQU), Branch Creation (STDCRBRN), and Customer Account Creation (STDCRACC) screens.
To invoke this screen, type ’PIDECALV’ in the field at
the top right corner of the application toolbar and click the adjoining
arrow button.
External
system
Specify the external credit approval system.
Description
Give a brief description in the external credit approval system.
2.4.2 Maintaining Queue Details for ECA system
You can maintain the external system details from which credit approval
for debit entries has to be obtained in the ‘External Credit Approval
System’ screen.
To invoke this screen, type ‘ PIDECAMT’ in the field at the top right corner
of the application toolbar and click the adjoining arrow button.
External
Credit Approval System
Description
Preferences
Inqueue JNDI Name
Specify the name for ECA response queue configured in Application
server.
Outqueue JNDI Name
Specify the name for ECA request queue configured in Application server.
Initial Context Factory Class
Specify the initial context factory class.
Context Provider URL
Specify the context provider URL.
Queue Factory JNDI
Specify the queue factory JNDI.
Timeout in seconds
Specify the time out in seconds. If there is no response within this
time, then the request is marked as timed out.
Inter System Bridge GL
Specify or select the inter system bridge GL.
External System User ID
Specify the external system user id.
Queue Authentication
Queue Authentication Required
Select this check box to indicate that Queue Authentication is required
for the External Credit Approval System.
User ID
Specify the required User Name.
Password
Enter the password. The User Id and Password that you specify is used
for verification purposes. The password is encrypted and stored.
ECA System Class
Select the ECA system class as ‘External’ or ‘FCUBS’.
Status Mapping
External Response Code
Specifies the code assigned to a status by external ECA system.
Status Description
Specifies the status description of the external response code.
System Status
Specifies the ECA status derived in the system. Choose among the following:
Automatic Cancellation
Select whether automatic cancellation of the payment is applicable
or not. You can select Yes only if the response codes are mapped to Rejected
status.
2.4.3 Maintaining Queue Details for External Accounting
System
While posting the accounting entry, ECA reference number is provided
to unblock the blocked amount. Debit which does not have an ECA reference
number goes as a normal debit.
If different External Accounting System and ECA systems are maintained:
- During accounting handoff, an additional intimation is
sent to the ECA system. This is to indicate the ECA system that the accounting
for the transaction is handed off.
- The ECA system’s reference number is also shared
to the External Accounting System along with accounting handoff.
- Thus, the ECA and the External Accounting Systems need
to reconcile on releasing the amount block posted earlier and execute
the debit transaction.
You can maintain the details of External Accounting System to which
accounting entries handoff is sent during transaction processing. The
accounting entries generated by OBCL system is handed off to this accounting
system.
To invoke this screen, type ‘ PIDACCMT’ in the field at the top right corner
2.4.4 Configuring Accounting System for Host Code
You can configure the accounting system using host code in the ‘Host
Parameter’ screen.
To invoke this screen, type ‘PIDHSTMT’ in the field at the top right corner
Specify the following
details
Host Code
Specify the host code.
Host Description
Specify the brief description for the host.
Accounting System Code
Specify the accounting system code
2.4.5 Viewing ECA Queue Summary Details
ECA Queue Summary screen contains details on the transactions between
OL and external system.
To invoke this screen, type PISECAQU’ in the field at the top right corner
You can search records
based on the following parameters:
- Transaction Reference No
- Network code
- ECA Amount
- Customer No
- Requested Date
- Authorization Status
- Cross Border Contract Reference Number
- Activation Date
- File Reference Number
- Payment Transaction Type
- ECA Currency
- Current Status
- Response Date
- Maker Id
- Payment Type
- Customer Service Model
- Queue Reference No
- Transaction Branch
- Module
- Response Status
- ECA System Code
- Checker Id
- Source Code
Click ‘Search’ button with or without entering any of
the above search parameters. All records matching the search criteria
are displayed. To view a particular record double-click on the desired
record displayed in the list of records. The details pertaining to each
record is displayed:
