1. Preface
1.1 Introduction
This document is designed to help acquaint you with the integration among Oracle FLEXCUBE products namely; Oracle FLEXCUBE Enterprise Limits and Collateral Management system (FCELCM), Oracle FLEXCUBE Universal Banking Solutions (FCUBS) and Oracle Banking Corporate Lending (OBCL).
Besides this user manual, while maintaining the interface related details, you can invoke the context sensitive help available for each field. This help describes the purpose of each field within a screen. You can obtain this information by placing the cursor on the relevant field and pressing the <F1> key on the keyboard.
1.2 Audience
This manual is intended for the following User/User Roles:
Role
Function
Back office data entry Clerks
Input functions for maintenance related to the interface
Back office Managers/Officers
Authorization functions
End of day operators
Processing during end of day/ beginning of day
Implementation Partners
Provide customization, configuration and implementa­tion services
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Organization
This manual is organized into the following chapters:
Chapter
Description
Chapter 1
Preface gives information on the intended audience. It also lists the vari­ous chapters covered in this User Manual.
Chapter 2
ELCM Integration with OBCL/FCUBS explains the various integration sce­narios of ELCM integration with OBCL/FCUBS.
Chapter 3
Annexure provides the technical changes of integration.
Chapter 4
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.5 Acronyms and Abbreviations
Abbreviation
Description
BC
Bills and Collection
CD
Corporate Deposit
EJB
Enterprise Java Beans
ELCM
Oracle FLEXCUBE Enterprise Limits and Collateral Management sys­tem
FCUBS
JDBC
Java Database Connectivity
JPA
Java Persistence API
LC
Letter of Credit
MM
Money Market
OBCL
ODT
Open Development Tools
POJO
Plain Old Java Object
SQLJ
A SQLJ program is a Java program containing embedded SQL state­ments.
TD
Term Deposit
XML
eXtensible Markup Language
1.6 Glossary of Icons
This user manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
1.7 Related Information Sources
Along with this user manual, you may also refer to the following related sources:
