1. Preface
1.1 Introduction
This manual is designed to help you to quickly get acquainted with the Oracle FLEXCUBE Enterprise Limits and Collateral Management (hereafter referred to as Oracle FLEXCUBE ELCM) system. It provides an overview and takes you through the various steps involved setting up and maintaining the Oracle FLEXCUBE ELCM system.
You can further obtain information specific to a particular field by placing the cursor on the relevant field and pressing <F1> on the keyboard.
1.2 Audience
This manual is intended for the following User/User Roles:
Role
Function
Back office data entry clerk
Input functions for funds
Back office managers/officers
Authorization functions
Product Managers
Product definition and authorization
End of day operators
Processing during end of day/ beginning of day
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at
1.4 Organization
This manual is organized into the following chapters:
Chapter 1
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual.
Chapter 2
Limits & Collaterals explains a series of maintenance options facilitated by Oracle FLEXCUBE for Enterprise Limits and Collateral Manage­ment.
Chapter 3
Credit Desktop discusses the integrated credit desktop of Oracle FLEX­CUBE
Chapter 4
Queries explains about the query functions and helps you to query
records on Liabilities, Transactions, Collateral Covenants, and so
on.
Chapter 5
Reports provide a list of reports that can be generated in this module and also explains their contents.
Chapter 6
Annexure 1 - Utilization Transactions explains how to maintain all utili­zation transactions in Oracle FLEXCUBE ELCM.
Chapter 7
Annexure 2 - Value Dated Facility discusses the feature to maintain facility details based on a specific value date.
Chapter 8
Annexure 3 – Revaluation describes how to maintain the fluctuating exchange rates of marketable securities such as currency and collat­eral, over a period of time.
Chapter 9
Annexure 4 - Gateway Processes & Interfaces details on how an exter­nal system can be integrated with Oracle FLEXCUBE ELCM system for communication.
Chapter 10
EOD - BOD Batches discussed the function IDs for EOD and BOD Batches.
Chapter 11
Notifications explains the various notification codes.
Chapter 12
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.5 Acronyms and Abbreviations
You may find the following acronyms/abbreviations in this manual.
UI
User Interface
ELCM
FCUBS
Oracle FLEXCUBE Universal Banking Solution
GW
Gateway
HTTP
Hyper Text Transfer Protocol
XML
eXtensible Mark-up Language
XSD
XML Schema Definition
XSLT
eXtensible Stylesheet Language Transformations
SMS
Security Services
ID
Identification Number
PK
Primary Key
RDBMS
Relational Data Base Management System
VD
Value Date
Mark EOTI
Mark End of Transaction Input
Mark TI
Mark Transaction Input
CIF
Customer Information File
1.6 Glossary of Icons
This User Manual may refer to all or some of the following icons:
Icons
Function
Exit
Add row
Delete row
Option List
