This Annexure lists the Interest and Charge (IC) rules that need to be maintained for the CASA module of Oracle FLEXCUBE. It also gives the UDEs and rates for which values need to be maintained.
The components required to calculate interest (the principal, period, and rate) are broadly referred to as ‘Data Elements’. Data elements are of two types:
In addition to specifying how the SDEs and UDEs are connected through the formulae, you also define certain other attributes for a rule using the ‘Interest & Charges Rule Maintenance’ screen. You can invoke this screen by typing ‘‘ICDURUMNT’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
For details about the screen, refer the chapter ‘Maintaining Interest Rules’ in the Interest and Charges User Manual.
You can maintain rules for the following:
Specify the following details:
On Account Opening Month
Check this box.
On Account Closure Month
Check this box.
SDE
Maintain the following SDEs:
UDE
Maintain the following UDEs:
User Defined Elements |
Type |
NORMAL_RATE1 |
Rate |
NORMAL_RATE2 |
Rate |
NORMAL_RATE3 |
Rate |
NORMAL_RATE4 |
Rate |
AMOUNT1 |
Amount |
AMOUNT2 |
Amount |
AMOUNT3 |
Amount |
TAX1 |
Rate |
Get Latest
For each of the UDEs, select the option ‘Use Effective’ from the adjoining drop-down list.
Click ‘Formulas’ button and invoke the ‘Formulas’ screen.
You need to maintain two booked formulae and one tax formula.
Periodicity
Select ‘Daily’ from the adjoining drop-down list.
Book Flag
Select ‘Booked’ from the adjoining drop-down list.
Debit/Credit
Select ‘Credit’ from the adjoining drop-down list.
Days in a Month
Select ‘Actuals’ from the adjoining drop-down list.
Days in a Year
Select ‘365’ from the adjoining drop-down list.
Accrual Required
Check this box.
Rounding Required
Check this box.
Click ‘Formula Wizard’ button and invoke the ‘Formula Wizard’ screen.
In this screen, specify the following expressions:
Case |
Result |
(VD_DLY_CR_BAL_M >=0 AND VD_DLY_CR_BAL_M <= AMOUNT2) |
(VD_DLY_CR_BAL_M*NORMAL_RATE1*DAYS)/(YEAR*100) |
(VD_DLY_CR_BAL_M > AMOUNT2 |
(VD_DLY_CR_BAL_M*NORMAL_RATE3*DAYS)/(YEAR*100) |
Book Flag
Periodicity
Debit/Credit
Select ‘Debit’ from the adjoining drop-down list.
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Click ‘Formula Wizard’ button and invoke the ‘Formula Wizard’ screen. In this screen, you need to maintain the following expressions:
Case |
Result |
VD_DLY_DR_BAL_M >=AMOUNT3 |
(VD_DLY_DR_BAL_M <AMOUNT3 |
(VD_DLY_DR_BAL_M*NORMAL_RATE4*DAYS)/(YEAR*100) |
Book Flag
Select ‘Tax’ from the adjoining drop-down list.
Periodicity
Select ‘Periodic’ from the adjoining drop-down list.
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Leave this box unchecked.
Rounding Required
Check this box.
Case |
Result |
FORMULA1 > AMOUNT1 |
(TRUNC((FORMULA1*TAX1)/100) |
(FORMULA1 < AMOUNT1 |
0 |
Check this box.
Check this box.
SDE
UDE
Type
For each of the UDEs, select the option ‘Rate’ from the adjoining drop-down list.
Get Latest
Click ‘Formulas’ button and invoke the ‘Formulas’ screen. You need to maintain two booked formulae and one non-booked formula.
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Click ‘Formula Wizard’ button and invoke the ‘Formula Wizard’ screen. In this screen, you need to maintain the following expression:
Case |
Result |
DLY_NET_BAL_M > 0 |
ABS((DLY_NET_BAL_M*NORMAL_RATE1*DAYS)/(YEAR*100)) |
Book Flag
Select ‘Non-Booked’ from the adjoining drop-down list.
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Rounding Required
Check this box.
Case |
Result |
DLY_NET_BAL_M <0 |
ABS(DLY_NET_BAL_M) |
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box if rounding is required.
Case |
Result |
FORMULA2> ACCOUNT_LIMIT |
ABS((DLY_NET_BAL_M*NORMAL_RATE2*DAYS)/(YEAR*100)) |
FORMULA2< ACCOUNT_LIMIT |
ABS((DLY_NET_BAL_M*NORMAL_RATE3*DAYS)/(YEAR*100)) |
Check this box.
Check this box.
SDE
UDE
Type |
RATE1 |
Rate |
RATE2 |
Rate |
AMOUNT1 |
Amount |
AMOUNT2 |
Amount |
TAX1 |
Rate |
TAX2 |
Rate |
Get Latest
Click ‘Formulas’ button and invoke the ‘Formulas’ screen. You need to maintain two booked formulae and one tax formula.
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Interest Method Default From Currency Definition
Check this box.
Case |
Result |
( MON_AVG_BAL <0 |
ABS((MON_AVG_BAL*RATE1*DAYS)/(YEAR*100)) |
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Case |
Result |
MON_AVG_BAL >0 |
ABS((MON_AVG_BAL*RATE2*DAYS)/(YEAR*100)) |
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Leave the box unchecked.
Rounding Required
Check this box.
Case |
Result |
FORMULA2 < AMOUNT1 |
0 |
FORMULA2>AMOUNT1 |
TRUNC((FORMULA2*TAX1)/100) |
FORMULA2>AMOUNT2 |
TRUNC((FORMULA2*TAX2)/100) |
Check this box.
Check this box.
SDE
UDE
Type |
NORMAL_RATE1 |
Rate |
NORMAL_RATE2 |
Rate |
NORMAL_RATE3 |
Rate |
NORMAL_RATE4 |
Rate |
AMOUNT1 |
Amount |
AMOUNT2 |
Amount |
AMOUNT3 |
Amount |
TAX1 |
Rate |
Get Latest
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box..
Click ‘Formula Wizard’ button and invoke the ‘Formula Wizard’ screen. In this screen you need to maintain the following expressions.
Case |
Result |
VD_DLY_CR_BAL_M >=0 AND VD_DLY_CR_BAL_M <= AMOUNT2 |
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Case |
Result |
(VD_DLY_DR_BAL_M*NORMAL_RATE2*DAYS)/(YEAR*100) |
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Rounding Required
Check this box.
Case |
Result |
0 |
Check this box.
SDE
UDE
Type |
NORMAL_RATE1 |
Rate |
NORMAL_RATE2 |
Rate |
NORMAL_RATE3 |
Rate |
NORMAL_RATE4 |
Rate |
AMOUNT2 |
Amount |
AMOUNT3 |
Amount |
Get Latest
Click ‘Formulas’ button and invoke the ‘Formulas’ screen. You need to maintain two booked formulae.
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Case |
Result |
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Case |
Result |
Check this box.
Check this box.
SDE
UDE
Type |
AVSLAMT1 |
Amount |
AVSLAMT2 |
Amount |
AVSLAMT3 |
Amount |
AVSLAMT4 |
Amount |
AVSLAMT5 |
Amount |
CHGAMT1 |
Amount |
CHGAMT2 |
Amount |
CHGAMT3 |
Amount |
CHGAMT4 |
Amount |
CHGAMT5 |
Amount |
TAX3 |
Rate |
Get Latest
Click ‘Formulas’ button and invoke the ‘Formulas’ screen. You need to maintain one booked formula and one tax formula.
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Rounding Required
Check this box.
Case |
Result |
MON_AVG_BAL >0 AND MON_AVG_BAL > MIN_BAL_REQD |
0 |
MON_AVG_BAL < AVSLAMT1 |
CHGAMT1 |
MON_AVG_BAL < AVSLAMT2 AND MON_AVG_BAL > AVSLAMT1 |
CHGAMT2 |
MON_AVG_BAL < AVSLAMT3 AND MON_AVG_BAL > AVSLAMT2 |
CHGAMT3 |
MON_AVG_BAL < AVSLAMT4 AND MON_AVG_BAL > AVSLAMT3 |
CHGAMT4 |
MON_AVG_BAL < AVSLAMT5 AND MON_AVG_BAL > AVSLAMT4 |
CHGAMT5 |
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Rounding Required
Check this box.
Case |
Result |
FORMULA1 >0 AND FORMULA1 < MON_AVG_BAL |
TRUNC((FORMULA1*TAX3)/100) |
Check this box.
Check this box.
SDE
UDE
Type
For each of the UDEs, select the option ‘Amount’ from the adjoining drop-down list.
Get Latest
Click ‘Formulas’ button and invoke the ‘Formulas’ screen. You need to maintain one booked formula.
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Rounding Required
Check this box.
Case |
Result |
AC_DORMANT =1 AND (AC_DORMANCY_DAYS >=1 AND AC_DORMANCY_DAYS <=30) |
AC_DORMANCY_DAYS*DORM_CH_PER_DAY1 |
AC_DORMANT =1 AND AC_DORMANCY_DAYS >30 |
AC_DORMANCY_DAYS*DORM_CH_PER_DAY2 |
You can maintain UDE values for the rules using the ‘Interest and Charges User Data Element Maintenance’ screen. You can invoke the ‘Interest and Charges User Data Element Maintenance’ screen by typing ‘ICDUDVAL’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
For details about the screen, refer the chapter ‘Giving UDE Values for Condition’ in the Interest and Charges User Manual.
In this screen, you need to maintain the following UDEs for the different IC products. Assume that you have maintained the following interest products:
You need to maintain values for the following UDEs under this product:
You need to maintain value for the UDE, STAMP_DUTY, under this product.
In addition to specifying how the SDEs and UDEs are connected through the formulae, you also need to define certain other attributes for a rule using the ‘Interest and Charges Rule Maintenance’ screen. You can invoke this screen by typing ‘ICDRLMNT’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
Specify the following parameters in the Formulas section of the Interest & Charges Rule Maintenance screen:
Debit/Credit
Select ‘Debit’ from the Debit/Credit list.
Book Flag
Select ‘Booked’ from the Book Flag list.
Periodicity
Select ‘Quarterly’ from the Periodicity list.
Case |
Result |
CURRENT_BAL < 0 |
((CURRENT_BAL*STAMP_DUTY) * -1) |
You can maintain rate codes for branches using the ‘Interest and Charges Branch Availability Maintenance’ screen. You can invoke this screen by typing ‘ ‘ICDBRSTR’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
You need to maintain the following rate code for all branches of your bank:
For the aforesaid rate code, you need to maintain rates and effective dates in the ‘Interest and Charges Rate Input’ screen. You can invoke the ‘Interest and Charges Rate Input’ screen by typing ‘ICDRATMA’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
These rates are picked up by the CASA module while processing interest applicable on a CASA.
Refer the chapter ‘Floating Rate Codes for IC Module’ for details about rate maintenance.
