This manual talks about the interface between Oracle FLEXCUBE and the Oracle Identity Manager system used in your bank. The maintenances required for the proper functioning of this interface, the interface workflow, validations, and processing for the interface have been documented in this manual.
This manual is intended for the following User/User Roles:
Role |
Function |
Back office data entry Clerks |
Input functions for maintenance related to the interface. |
Back office Managers/Officers |
Authorization functions. |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized as follows:
Chapter |
Description |
Chapter 1 |
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
Chapter 2 |
Oracle FLEXCUBE - Oracle Identity Manager Interface explains about the integration and configuration of OIM with Oracle Flexcube. |
Chapter 3 |
Annexure A details about the OIM Components and the various Messages generated within the module. |
Chapter 4 |
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
Abbreviation |
Description |
System |
Unless specified, it shall always refer to Oracle FLECUBE |
OIM |
Oracle Identity Manager |
SPML |
Service Provisioning Mark-up Language |
DSML |
Directory Service Mark-up Language |
GTC |
Generic Technology Connector |
This manual is organized into the following chapters:
Chapter |
Description |
Chapter 1 |
Chapter 2 |
Oracle FLEXCUBE – Oracle Identity Manager Interface: Oracle Identity Manager Interface helps in integrating the two systems for user provisioning and de-provisioning services. |
Chapter 3 |
Annexure A - deals with the: OIM Components, SPML Request and Response Message Formats, Message Exchange Sequences. |
This User Manual may refer to all or some of the following icons.
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
Refer the Procedures User Manual for further details about the icons.
You may refer the following manuals for more information
