2. Oracle FCUBS - ELCM Integration
Banks extend various credit facilities like limits to its customers
depending on their requirements. Based on the bank’s business model
and their target customers they have one of the following scenarios:
- Banks extending basic credit facilities to customers like overdraft
or small loans who will prefer to manage the limits within the core banking
system (Standalone FCUBS installation)
- Banks dealing with corporates who require trade finance and treasury
that requires limit to be routed through dedicated system to manage the
collateral and limit details
2.1 Scope
This section contains the following topic:
2.1.1 FCUBS Installation Modes
This document talks about two types of FCUBS installation modes. They
are:
- FCUBS with No External Limits - For this installation mode limit
support is within FCUBS through local facility and local collateral
- FCUBS with External Limits - The integration supports the following
modes of FCUBS - Limits installation:
- Standalone Limits system with FCUBS - SYNC Method
- Standalone Limits system with FCUBS - ASYNC Method
- Componentized limits installation - SYNC Method
- Componentized limits installation - ASYNC Method
- Embedded Limit Installation with FCUBS
Details
Standalone
Componentized
Embedded (5)
SYNC (1)
ASYNC (2)
SYNC (3)
ASYNC (4)
Data Storage
Different DB
Different DB
Same DB
Same DB
Same DB
Deployment
Different App.
Different App.
Same App.
Same App.
Same App.
Mode Interface
Web Services
Web Services
Web Services
Web Services
JDBC/POJO
Limit Response Handling
Online
Deferred
Online
Deferred
Online
2.2 Prerequisites
Set up Oracle FLEXCUBE Universal Banking Application. ELCM user will
have read-only access to this application. The access is provided only
to particular extraction tables.
Refer the ‘Oracle FLEXCUBE Universal Banking Installation’
manual.
2.3 Integration Process
2.3.1 Installation Modes
The following installation modes are described in the upcoming sections:
- ASYNC Installation for Standalone and Componentized
- SYNC Installation for Standalone and Componentized
2.3.1.1 ASYNC Installation (Standalone
and Componentized)
If the mode of limits installation is selected as ASYNC (Standalone/Componentized),
the limits requests will be logged with Limits Pending Status in FCUBS
Limits Queue. These pending limits requests are picked by a job to form
the webservices XML requests. The status of the limit request will be
updated in FCUBS based on the external limits response. The status can
be Approved, Rejected or Timed-out. FCUBS will authorize the transactions
that are in Approved status.
ASYNC Installation Architecture
Limit
Processing Queue
You can query and perform manual actions on external limit requests
using Limit Processing Queue screen. This screen supports user action
only on timed out requests. You can invoke this screen by typing ‘SQSEXLMT’ in the top right corner of the Application
toolbar and clicking the adjoining arrow button.
You can view
records based on any or all of the following criteria:
- Branch Code
- Process Status
- Authorization Status
- Transaction Ref No
- External Status
- Customer No
- Destination Source
Select any or all of the parameters for a query and click ‘Search’
button. The records meeting the selected criteria are displayed.
External Limit Queue supports user actions only on a timed out request.
A limit request is moved to ‘Timed-out’ status based on the
time out parameter maintained. If response is not received from the external
system within the given time, the status is marked as timed out. The
following actions are allowed on a timed out requests:
- Approve - Manual approval of external limits
- Reject - Manual rejection of external limits
- Authorize - Authorization of external limits approval or reject done
from queue
- Resend - Resend of timed-out request
2.3.1.2 SYNC Installation (Standalone
and Componentized)
If the mode of limits installation is selected as SYNC (Standalone/Componentized):
- the limit transactions are processed in the transaction time window
- FCUBS creates the limit request during the transaction and sends
it to the external limit system
- the response received from the external limit system along with the
overrides and errors are displayed to the user during the transaction
- the user can approve the limits overrides and proceed with the transactions
from FCUBS
2.3.1.3
If mode of installation is selected as embedded limits installation,
then FCUBS and ELCM are installed as embedded system. All the limit utilization
will be processed online and the response is provided to the user in
the transaction window.
2.3.2 Integration Maintenance and Processing
2.3.2.1 Installation Parameters
You can select the required external limit setup mode and communication
mode during installation.
Limit Setup Mode (ELCM SETUP MODE)
The following parameters can be used for limit setup mode:
- N - Should be used for No External Limit setup (default)
- S - Standalone UBS - Limits setup/ Componentized Limits setup
- E - Embedded UBS Limit setup
External Limit Interface Mode (UBS_EL_COMM_MODE)
The following parameters can be used for external limit interface
mode:
- A - Asynchronous
- S - Synchronous
This is applicable for Standalone UBS - Limits setup/ Componentized
Limits setup.
2.3.2.2 FCUBS with No External Limits
Installation
If FCUBS is installed with no external limits:
- Local facility can be created using ‘External Facilities Maintenance’
(STDCRFAC) screen
- Local collateral can be created using ‘Local Collateral Maintenance’
(STDCOLAT) screen
- Linkage can be done at customer account and module level as applicable
- FCUBS does the utilization tracking and validations for local facilities
and collaterals
2.3.2.3 FCUBS with External Limits Installation
If FCUBS is installed with external limits, then:
- following limit details are replicated from external system to FCUBS:
- Liability details
- Customer liability linkage
- Facility details
- Collateral details
- Collateral pool details
- local collateral can be created using the ‘Local Collateral
Maintenance’ (STDCOLAT) screen
- linkage is done at customer account and module level
- for local facility and collateral FCUBS tracks the limit balances
and performs the validations, and hands over the utilisation to the external
system
- you can also link global limits as applicable based on the data replicated
- for non-local limit types, FCUBS does the limit processing based
on the external system response.
- in case of Batch operation FCUBS posts the utilisation to external
limits as Force Post
