The integration between the Oracle FLEXCUBE Universal Banking System (FCUBS) and Oracle FLEXCUBE Payments (PM) allows you to trigger notification during creation, modification or authorization of Customer, Customer Account, Currency Rate, GL Code and Transaction Code. The integration also allows you to provide response to the external system request on exchange rate lookup and utilization, de-utilization of an FX contract.
This section describes the scope of the integration with respect to FCUBS and PM.This section contains the following topics:
You can generate notification to an external system if the following details are created, modified or authorized in FCUBS:
You can process exchange rate lookup and utilization or de-utilization on an FX contract linked to an external payment system. The system hands over the process response along with the exchange rate details to the external system.
Set up Oracle FLEXCUBE Universal Banking Application and Oracle FLEXCUBE Payments Application.
Refer the ‘Oracle FLEXCUBE Universal Banking Installation’ manual.
This section contains the following topic:
Notification framework in FCUBS is used to communicate the business event in FCUBS to external systems. Depending on the event an XML message is send to external system queues.
You can trigger notification message to an external system when the following details are created or modified on authorization:
The system generates a notification when the above created or modified details are authorized.
You can process exchange rate lookup and utilization or de-utilization request if an FX contract is linked to an external payment system.
