This manual is essentially designed to help you set up products in Oracle FLEXCUBE. It takes you through the various steps involved in creating a product. Further, you can obtain information specific to a particular field by placing the cursor on the relevant field and striking <F1> on the keyboard.
This manual is intended for the following User/User Roles:
Role |
Function |
Back office clerk |
Input functions for contracts |
Back office managers/officers |
Authorization functions |
Product Managers |
Product definition and authorization |
End of day operators |
Processing during end of day/ beginning of day |
Financial Controller/Product Managers |
Generation of reports |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized as follows:
Chapter |
Description |
Chapter 1 |
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
Chapter 2 |
Product Definition explain about what a product means Oracle FLEXCUBE and the process of defining the same. |
Chapter 3 |
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
This User Manual may refer to all or some of the following icons:
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
For further information on procedures discussed in the manual, refer to the Oracle FLEXCUBE manuals on:
