The Settlements sub-system is part of the core of Oracle FLEXCUBE. This system is a central money settlement service that interfaces with the other modules of Oracle FLEXCUBE.
In Oracle FLEXCUBE, the Settlements and Messaging systems are closely associated. The Settlements system provides for a common set up of money settlement accounts and routes. The Messaging system, on the other hand, handles the generation of settlement messages.
To handle money settlements in Oracle FLEXCUBE, you have to:
Banks exclude certain IBAN national IDs from being used as bank codes in Oracle FLEXCUBE. The exclusion list must be uploaded into the system using ‘BIC Upload’ screen. When an IBAN national ID is excluded, the IBAN is considered to be invalid.
The invalid IBANs specified in the exclusion will not be available for selection while you enter a bank code during any operation in the system. That is, whenever you try to enter an IBAN in the system, it will be validated against the IBAN national ID exclusion list as of that date.
You can view a summary of IBAN national ID exclusions using ‘IBAN Exclusion List Summary’ screen. To invoke the screen, type ‘ISSIBEXCL’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
Even if you have uploaded the exclusion list, you can see the IBAN national ID in this screen only from the date of activation of the exclusion.
You can search for the records based on one or more of the following parameters:
Once you have specified the search criteria, click ‘Search’ button. The system displays the above details of excluded IBAN national IDs that match the search criteria.
The IBAN national IDs in the exclusion list is uploaded to the system can be viewed in ‘IBAN Exclusion List’ screen. From the ‘IBAN Exclusion List Summary’ screen, you can double-click a record to view the detailed screen. You may also type ‘ISDIBEXCL’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
If you have directly accessed this screen, you may enter a query by clicking ‘Enter Query’ button. You can specify the record key and click ‘Execute Query’ button to view the details.
The following details are displayed:
The customer IBAN number is validated for the length, IBAN check digit and national ID. For the IBAN to be considered as valid, following conditions should be satisfied.
The beneficiary IBAN number is validated for the length, IBAN check digit and national ID.
IBAN check digit and national ID validations are applicable only if the global parameter ‘IBANPLUS_REQD’ is set to ‘Y’.
You can maintain the details related to the beneficiary of transaction through ‘Ultimate Beneficiary Maintenance’ screen. You can invoke this screen by typing ‘ISDUTBEN’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button. If you are maintaining details of a new beneficiary, select ‘New’ from the Actions Menu in the Application toolbar or click new icon.
You can specify the following details in this screen:
Beneficiary Name
Specify the name of the ultimate beneficiary for whom you are maintaining details. You can maintain several settlement combinations for an Ultimate Beneficiary
Beneficiary Account
Specify the account number of the ultimate beneficiary to which funds need to be credited. The account number should be a valid account with the bank that you specify in the BIC Code field.
Beneficiary Address
Specify the address of the ultimate beneficiary. Each row can contain a maximum of thirty five alphanumeric characters.
Country Code
Specify country code of the ultimate beneficiary for whom you are maintaining details or select the country code from the option list provided.
Receiver Bank Identification Code
Specify the Bank Identification Code (BIC) of the receiver bank or select the BIC from the option list provided.
Account With Institution Bank Identification Code
Specify the Bank Identification Code (BIC) of the Account with Institution bank or select the BIC from the option list provided.
Customer Information File Number
Specify the CIF number of the ultimate beneficiary for whom the details are being maintained or select the CIF number from the option list provided.
You can indicate the mode of sending advice to beneficiary here. The following options are available:
Fax Number
Specify the fax number of the ultimate beneficiary for whom you are maintaining details.
Mobile Number
Specify the mobile number of the ultimate beneficiary for whom you are maintaining details.
Email Address
Specify the email address of the ultimate beneficiary for whom you are maintaining details.
Note
You can specify only one of the options among fax number, mobile number and e-mail address.
Multimode settlement is applicable only for Consumer lending module of Oracle FLEXCUBE. All settlements are, typically, made using accounts. However, in Oracle FLEXCUBE, settlements can be done through different modes in addition to the account level settlement. The different modes can be:
You can also make settlements using a combination of any of the modes mentioned above i.e. part by cash, part by cheque and the rest by credit card or any other combination of your choice.
You can capture the different modes of settlement through the ‘Multimode Settlement Maintenance’ screen. You can invoke this screen by typing ‘ISDSRCMD’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button. The modes are captured for a Source, Module, Product and Currency combination.
The following details have to be captured in this screen:
Source
Oracle FLEXCUBE interfaces with other external systems of your bank. Transactions originating in external systems may require to be uploaded into Oracle FLEXCUBE for further processing. For maintaining the settlement modes for such transactions, you have to indicate the source code of the external system here. The source codes of all external systems are available in the option-list provided from where you can make the appropriate selection.
You may use the Source Code ‘Oracle FLEXCUBE’ to maintain settlement modes for transactions originating in Oracle FLEXCUBE.
Module
You have to specify the module of the transactions that have to be settled using different modes. The value of this field is defaulted to CL (Consumer Lending). You cannot modify this value.
Product
Here, you have to indicate the product of the transactions that have to be settled using different modes. The option-list will display the different products available under the selected module. You may also use the wild character ‘****’ as the product code. The system will use this information if settlement mode maintenance is not available for a product under the selected module.
Currency
You have to specify the currency of the transactions that have to be settled using different modes. You may also use the wild character ‘***’ for a currency. This will be used if maintenance for a specific currency is not available.
For the above combination of Source, Module, Product and Currency, you can maintain multiple settlement modes and the associated details given below:
Setl Mode
For the selected combination, you have to specify the settlement mode. The list of available modes is predefined in the system and you can select a mode from the drop-down list. Since CL is the module used for the multimode settlement the different modes available are:
Pay Setl Ac
For the selected settlement mode, you have to specify the Suspense/Control GL into which the transactions (that satisfy the selected combination) need to pass the accounting entry. This GL will be used only when the bank is making a payment. The settlement account gets credited in this case.
Pay Setl Prod
For the selected settlement mode, if the originating transaction results in a linked transaction, you need to specify the product that should be used to create the linked transaction. This product will be used when the settlement account gets credited. For example, if the settlement mode is ‘DD’, you have to specify the product code (i.e. the DD instrument type) for creating the corresponding instrument transaction in Oracle FLEXCUBE.
Recv Setl Ac
Just as you specify the pay settlement account for the mode selected, you also have to indicate the Suspense/Control GL into which transactions (that satisfy the selected combination) need to pass the accounting entry when the bank receives a payment. The selected account gets debited in this case.
Recv Setl Prod
If the originating transaction (payment received) results in a linked transaction, you have to specify the product to be used to create the linked transaction. This product will be used when the settlement account gets debited. For instance, if the settlement mode is ‘External Cheque’, you have to specify the clearing product to be used for creating the clearing transaction.
For details on multi mode settlement processing, refer the heading titled ‘Processing settlements’ in this chapter.
You can maintain the settlement preferences of a customer or a bank in the ‘Settlement Instructions Maintenance’ screen. You can invoke this screen by typing ‘ISDINSTN’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
Indicating preferences for an entity means defining the settlement accounts and a detailed settlement route comprising the correspondent accounts and the intermediaries through which payment is to be routed. (The party information you can capture adheres to SWIFT standards.).
You can maintain the following basic settlement preferences for an entity (Customer /BIC), module, currency, product, Sequence Number and branch combination.
Counterparty Type
The Counterparty Type can either be CIF or BIC depending on whether your bank has an accounting relationship with the party for whom the instruction is being maintained or whether it only has a SWIFT messaging relationship. If the counterparty is a CIF in Oracle FLEXCUBE, you will have to select CIF as the party type and choose the relevant CIF ID in the adjacent field.
However, if the entity is not an actual customer of your bank but you would be sending/receiving payment messages to/from that party, you will have to choose BIC as the counterparty type and specify the counterparty’s address as well. As a result, you will need to identify the preferred Nostro/ Vostro accounts for that currency and BIC code combination.
Note
While processing an FT for the customer the appropriate charge account is picked up depending on the customer, currency and branch processing the FT.
In addition, you can maintain the details of the various intermediaries involved in payments and receipts. The preferences maintained for an entity determine the manner in which money settlements are made on behalf of the entity.
Counter Party
You can maintain settlement instructions for all the customers or for specific customers only. From the option list select the specific customer number or choose the ALL option
Counterparty Name
The system displays the name of the specified counterparty based on the details maintained at ‘Customer Maintenance’ level.
Module
You can maintain different settlement instructions for different products. If you choose Module as ‘ALL,’ then the Product must also be chosen as ‘ALL’. If you choose a specific module for maintaining settlement instructions, then you can choose any Product available under the module from the option list provided. You can also choose ‘All’ to maintain settlement instructions for all products under the selected module.
Product Code
Indicate a specific product code or choose All from the option list. However, if you have chosen All in the Module field, this field will be defaulted to ALL. You will not be allowed to change this.
Currency
You can maintain settlement instructions for a particular currency or for all the currencies From the option list select the particular currency code or choose the ALL option.
Branch
You can maintain settlement instructions for all the branches or for a particular branch. From the option list select the particular branch code or choose the ALL option.
Payment By
Indicate the method of payment for both Outgoing as well as Incoming Payments, for a Branch, Account and Currency combination. The following options are available:
Note
You can indicate the payment method as ‘Clearing’ only,
No payment message will be generated for settlements routed through a Clearing House.
Note
You can select ‘Payment By’ as ‘Instrument’, to ensure the payment by Instrument in SI settlements screen and then the system would look for the instrument type.
Charge Details
Specify whether charges for the message are to be borne by the bank (ourselves) or the beneficiary, or will be shared. This information is inserted in Field 71A of an MT103 message involving the combination for which settlement instructions are being maintained. You can select one of the following options:
Cover Required
This indicates whether the payment has to be sent with a cover message. Check this box to enable this option.
Cover By
If you have indicated that a cover is required for payments involving the customer, then, in this field, you can indicate whether the cover is through messaging or through local clearing. Accordingly, you can choose the required option in this field.
If you indicate that cover is through messaging, and the payment is through local clearing, you need to maintain the local clearing counterparty details in the Local Clearing tab.
If you indicate that cover is through local clearing, you need to maintain the cover details in the Cover Details tab.
When maintaining settlement instructions for CLS deals, you should specify the module as ‘FS’ (FX Settlements). This will indicate that they are meant exclusively for CLS deals.
The pay and receive accounts specified for the settlement instructions will be used as the ‘Control Accounts’ for CLS deals.
Refer the ‘Continuous Linked Settlements’ chapter of the Foreign Exchange User Manual for details on the following:
Before funds actually reach the Ultimate Beneficiary of a payment, it may have to pass through several other banks or parties. You can capture details of the parties involved in a payment in the ‘Pay Parties’ sections of the ‘Settlement Instructions Maintenance’ screen.
These screens contain fields that mark possible routes of a payment.
Intermediary Reimbursement Institution
An ‘Intermediary Reimbursement Institution’ is the financial institution between the Sender’s Correspondent and the Receiver’s Correspondent, through which the reimbursement of the transfer takes place.
Country
Specify the country of the intermediary reimbursement institution. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
Intermediary
The ‘Intermediary’ in a payment refers to the financial institution, between the ‘Receiver’ and the ‘Account With Institution’, through which the transfer must pass.
The Intermediary may be a branch or affiliate of the Receiver or the account with Institution, or an entirely different financial institution. This field corresponds to field 56a of a SWIFT message.
You can either enter the:
Country
Specify the country of the intermediary institution. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
Note
The country information is captured to enable Mantas to analyse the transactions for possible money laundering activities.
For more details on Mantas, refer 'Mantas' interface document.
RTGS Payments
If the settlement chosen is one of the RTGS Nostro that is, RTGS outgoing Nostro account in case of Outgoing customer and Bank transfer and RTGS incoming Nostro in case of outgoing Direct Debit transfer then the system will check this check box as per the validations done in RTGS Network. You cannot change this value.
RTGS Network
If in a RTGS Network the accounts are maintained as ‘Pay account’ or ‘Receiver Account’ while saving the settlement instruction, then a set of validations will be performed as mentioned below:
For Pay message, system will validate whether the intermediary (if intermediary is not present, the Account with Institution (AWI) will be validated and if the AWI is also not present then receiver will be validated) is a RTGS participant.
For Pay+ Cover message, system will validate if the receiver correspondent is a RTGS network participant.
If the above conditions are satisfied, the RTGS Network will be updated and the system will check RTGS Payments check box.
The ‘Receiver’s Correspondent’ is the branch of the Receiver, or another financial institution, at which the funds will be made available to the Receiver.
Receivers Correspondent
This field corresponds to field 54a of S.W.I.F.T. Enter the branch of the Receiver or another financial institution at which the funds will be made available to the Receiver. You can enter any one of the following:
Country
Specify the country of the branch of the receiver / institution. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
Sender to Receiver Information
The sender to receiver information maintained in the settlement instructions can be defaulted in the field 72 in the confirmation messages. The adjoining option lists displays the following values:
If you choose, ‘/TSU/’, the code placed between slashes ('/') must be followed by the invoice number, a slash ('/') and the amount paid.
An ‘Account with Institution’ refers to the financial institution, at which the ordering party requests the Beneficiary to be paid. The Account With Institution may be a branch or affiliate of the Receiver, or of the Intermediary, or of the Beneficiary Institution, or an entirely different financial institution.
This field corresponds to Field 57A of a SWIFT message. You can enter one of the following:
Country
Specify the country of the account with institution. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one
Note
Receiver
You can specify the final Receiver as apart from the Account With Institution if the Ultimate Beneficiary desires that the payment message should be sent there. If this is not maintained, the Account With Institution becomes the default Receiver.
You can also capture the Sender to Receiver Information in this screen.
For more details relating to specific parties, please refer to the SWIFT manuals.
ERI Currency
For every Counterparty and 'In' Currency (combination) for which you maintain settlement instructions, you can define an Euro Related Information (ERI) Currency. The ERI Currency can be:
This is used during the transition period, settlements of components in 'In' currencies can be made either in the same currency or in the Euro (EUR) depending on the settlement account(s) maintained. Similarly, components in Euro can either be settled in EUR or in an 'In' currency. In the settlement messages that are generated (MT 100, MT202), the settlement amount would be reported in the Settlement Account Currency. However, you can opt to additionally furnish the value of the component in an ERI currency.
The ERI Currency that you specify for a Counterparty and 'In' currency (combination) will default in the ERI CCY field in the Settlements Message Details screen.
Settlement Through an Instrument or Message
When the actual settlement event for a contract (involving the entity) takes place, the payment and receive message details are updated in a message hand-off table. The Messaging system picks up the details from this table, and based on the formats set up, generates the messages.
Depending on the route funds take when you receive (incoming) payments, you can maintain Intermediary and Beneficiary Institutions in the ‘Receive Parties’ section of the ‘Settlements Instructions Maintenance’ screen.
Receiver Intermediary
This field corresponds to field 56a of S.W.I.F.T. Specify details of the financial institution between the ‘Receiver’ and the ‘Account With Institution’, through which the amount must pass. The Intermediary may be a branch or affiliate of the Receiver or of the Account With Institution, or an entirely different financial institution.
In this field you can choose to enter the:
Country
Specify the country of the receiver’s intermediary. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
This field corresponds to field 58a of S.W.I.F.T. Enter details of the institution in favor of which the payment is made. It is in reality the bank, which services the account of the ultimate beneficiary. You will be allowed to make entries into this field only for Bank transfers (MT 200 or MT 202). In this field you can enter either the:
Country
Specify the country of the beneficiary institution. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
Note
The Cover details are defaulted from the ‘Contract Online’ screen only for Outgoing Customer Transfers with Cover.
You can specify the following details:
Country
Specify the country of the beneficiary institution for cover. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
When you specify settlement instructions for a customer, you can indicate whether payment for local currency transactions is to be effected via messaging or over the local clearing network. You can also indicate whether a cover is required for payment, and whether the cover is through messaging or over the local clearing network.
You can specify these details in the Settlement Instructions screen. In the Payment By field, indicate the mode of payment, either Message or Clear Details; and in the Cover By field, indicate the mode through which cover must be available.
If you indicate payment over a clearing network, you must specify the account details of the external counterparties (both pay and receive accounts) in the ‘Clear Details’ tab in the ‘Settlement Instructions Maintenance’ screen. In case you choose the option ‘Clearing’, then a PC contract will be automatically created. This PC contract will be created based on the appropriate transaction currency based on the Clearing Network that is maintained as part of the Settlement Instructions.
For the counterparty details, you can specify the bank code, account and account name.
External Counterparty Pay Details
The description of the selected bank, where the external counterparty account resides, is displayed here.
External Counterparty Receive Details
If you indicate cover for payment via the local clearing network, you must specify the account details of the cover party, in the ‘Cover Details’ tab in the ‘Settlement Instructions Maintenance’ screen.
For the cover party account details, you can specify the bank code, account and account name.
The following scenarios are possible:
Cover Required |
Cover By |
Payment By |
Local Clearing Counterparty Details? |
Cover Details? |
Yes |
Message |
Message |
No |
No |
Yes |
Local Clearing |
Message |
No |
Yes |
No |
Message |
No |
No |
No |
Local Clearing |
Yes |
No |
Clearing Network for Local Clearing in Settlement Instructions
You can specify a clearing network during settlement instruction maintenance for the Pay Leg and the Cover details. This will be defaulted as part of Settlement pick-up during Contract input and used subsequently while generating a PC Contract.
The Counter-party name shows the list of Bank Codes for Cover Transfer and Bank Transfer. The system will validate that the Bank Code Type for both the Counter-party name and Counter-party Bank Code is the same. For Customer transfers, this would be a user enterable field.
You can define the default values for fields in MT 103 messages that are generated in respect of contracts involving the customer. When a contract is entered for the customer in any module, the values that you maintain here will be defaulted for MT 103 generation in respect of the contract.
You can maintain these details in the ‘Other Details’ tab in the ‘Settlement Instructions Maintenance’ screen.
You can maintain the default MT 103 values for the following fields:
Bank Operation Code
You can indicate the bank operation code that will be inserted in Field 23B of the MT 103 message. The options available are SPRI, SSTD, SPAY and CRED.
Note
If the Bank Operation Code contains SPAY, SSTD or SPRI, the following validations will be done:
Instruction Code
You can indicate the Instruction code that will be inserted in Field 23E of the MT103 message. The options available are CHQB, TELE, PHON, PHOI, REPA, INTC, TELI, SDVA, PHOB, TELB, HOLD, CORT and BONL.
Instruction Code Description
You can specify the additional information, if any, which would be inserted to qualify the Instruction Code in Field 23E of the MT103 message. The instruction code description can only be maintained for the instruction codes PHON, PHOB, PHOI, TELE, TELB, TELI, HOLD or REPA.
For instance, if the Instruction Code is REPA and the description is ‘Repayment’ then the text ‘REPA/Repayment’ is inserted in Field 23E.
Transaction Type
You can indicate the Transaction Type that will be inserted in Field 26T of the MT103 message.
Regulatory Reporting Details
You can indicate the Regulatory Reporting Details that will be inserted in Field 77B of the MT103 message.
Charges Details
You can indicate whether charges for the message are to be borne by the bank (ourselves) or the beneficiary, or will be shared. You can specify this in the Charges Details section, in the main Settlement Instructions screen.
This information is inserted in Field 71A of the MT103 message.
While processing contracts in Oracle FLEXCUBE, the settlement instructions maintained are resolved in the following sequence:
Level |
Counterparty |
CCY |
Module |
Branch |
1 |
Counterparty |
CCY |
MOD |
Branch |
2 |
Counterparty |
CCY |
Mod |
ALL |
3 |
Counterparty |
CCY |
ALL |
Branch |
4 |
Counterparty |
CCY |
ALL |
ALL |
5 |
Counterparty |
ALL |
MOD |
Branch |
6 |
Counterparty |
ALL |
MOD |
ALL |
7 |
Counterparty |
ALL |
ALL |
Branch |
8 |
Counterparty |
ALL |
ALL |
ALL |
9 |
ALL |
CCY |
MOD |
Branch |
10 |
ALL |
CCY |
MOD |
ALL |
11 |
ALL |
CCY |
ALL |
Branch |
12 |
ALL |
CCY |
ALL |
ALL |
13 |
ALL |
ALL |
MOD |
Branch |
14 |
ALL |
ALL |
MOD |
ALL |
15 |
ALL |
ALL |
ALL |
Branch |
16 |
ALL |
ALL |
ALL |
ALL |
The Settlement details for a contract or deal get defaulted based on the maintenance of settlement instructions for the Customer/BIC code involved in the transaction.
To invoke the ‘Settlement Details’ screen, click ‘Settlement’ button in the Contract Main screen of a module.
By default the settlement details of all components of a contract which affect a customer type of account (the Role Types can be Customer, Remitter, Beneficiary for all the events associated to the product for which the Role-to-Head mapping has not been provided to the product associated with the contract) are displayed in this screen.
For example,
As per the maintenance that you have done for a Product the following accounting entries will be posted during the initiation of a contract.
Accounting Role |
Amount Tag |
Dr/ Cr Indicator |
ASSETGL |
PRINCIPAL |
Debit |
CUSTOMER |
PRINCIPAL |
Credit |
To achieve this, in the Role to Head mapping sub-screen of the Product Definition screen you would have mapped the Accounting Role ASSETGL to an actual internal leaf GL of your Chart of Accounts. However, you would not have maintained such a mapping for CUSTOMER since this is a role whose value gets defined at the contract level based on the counterparty involved in the contract.
While processing a contract you can modify the following information pertaining to Settlements:
In the Settlement Instructions screen you would have maintained the settlement accounts for an entity, module, currency and branch combination.
While processing a contract, these details will be defaulted to the Settlement sub-screen of the contract main screen. You have the option of changing any or all of the settlement accounts while processing a contract.
The account details that get defaulted include the following:
Note
Account Description
The system displays a brief description on account.
Netting Indicator
In addition to maintaining a netting agreement for each counterparty, you have to specify whether or not the contract is under the netting agreement for each contract involving the counterparty.
Check this box to indicate that you would like to enable the Netting option for the various components (Amount Tags) involved in the transaction. These components could be commission, interest, tax, charges etc.
Rate Code
Specify rate code by selecting appropriate rate code frx‘om selection list. Following values are available:
Note
In case of charges, if charge currency and settlement currency are different, system applies mid rate.
Spread Definition
Select the spread definition from the adjoining drop-down list. The options available are:
Customer Spread
This defaults from your specification of tenor-wise spread for the relevant Currency Pair in the Customer Spread Maintenance screen. You can change this for a specific contract.
Original Exchange Rate
If the component currency is different from the account currency, the system requires an exchange rate for the conversion. The components of the final exchange rate used for conversion are:
The final exchange rate = Base Rate +/- Customer Spread (depending on whether it is a Buy or a Sell deal).
Note
If Customer Spread details for a specific counterparty (for the currency pair) are unavailable, the System looks for the customer spread maintained for the wildcard ALL entry. If even that is not available, then the Customer Spread defaults to zero.
The method of spread definition, whether percentage or points is also displayed.
Note
If you have specified an account that uses an account class that is restricted for the product, an override is sought when you attempt to save the contract.
Exchange Rate
For transactions involving any relationship pricing benefit scheme, the customer specific exchange rate derived by adding the original exchange rate and the customer spread maintained for the relationship pricing scheme, gets displayed here.
If Relationship Pricing is not applicable, Exchange Rate will be the same as the Original Exchange Rate.
For more details on customer specific exchange rates, refer the section titled ‘Specifying Pricing Benefit Details’ in Relationship Pricing user manual.
Negotiated Cost Rate
The system defaults the negotiated cost rate.
Negotiation Reference
The system displays the negotiation reference here.
Generate Message
Enable this option if a payment messages has to be generated for the settlement instruction.
IBAN Account Number
The system displays the IBAN Account Number.Euro Currency and Euro Amount
SWIFT messages (MT103/MT202) generated towards settlement can furnish the value of the settlement amount in both the settlement account currency, and a Euro Related Information (ERI) currency of your choice. If you opt to furnish the ERI value of the amount, you have to enter the following in this screen:
The system defaults to the ERI currency specified for the customer and currency combination. You can change the default ERI currency. The ERI amount that you specify will be validated against the Tolerance Limit specified for the ERI currency (in the Currency Maintenance screen).
Cross-currency Settlements of FX deals
Oracle FLEXCUBE allows cross currency settlements of foreign exchange deals that involve an ‘In’ currency. You can settle the ‘In’ currency leg in another ‘In’ currency or in ‘Euro’.
For example,
Assume you enter into the following foreign exchange deal. You sell 100,000 FRF against USD.
The scenario:
Since FRF is an ‘In’ currency, you can settle the sell leg of the deal through EUR (in this example). The settlement amount would be EUR 15444.015.
Suppressing Settlement Messages
Settlement messages, defined for components that fall due, will be generated automatically when the settlement actually happens for the respective component. You can suppress the generation of the settlement message, defined for a component, by clearing the check box in the ‘Gen Message’ field.
Note
If a component is to be paid the credit account chosen becomes the pay account. Similarly, if a component is to be received the debit account chosen becomes the receive account in the settlement maintenance.
The details of the payment have to be specified in the ‘Payment Details’ screen..
Payment By
Note
Depending on the method in which you want to settle the contract, you should specify either Instrument or Message details.
Details of Charge
In this section you can maintain details of the party who will bear the charges incurred in processing the transaction. It could be either:
Note
In FT Module, ‘Details of Charges’ is selected on the basis of value selected in ‘Charge Bearer’ field in the ‘Other Details’ tab.
Note
Here you can specify information, from the Ordering Party to the Beneficiary Customer, about the reason for the payment.
This field can contain reference numbers, invoice numbers or any other details, which will enable the Beneficiary to identify the transaction. This information is to be passed through the payment chain to the Beneficiary.
This field corresponds to field 70 of S.W.I.F.T. Refer to the S.W.I.F.T. manual for details on the code words and the format of the message you can input.
Banking Priority
Select the priority of the payment messages from the drop down list. The options available are:
The default value is Normal.
Information 1,2,3,4,5 and 6
This could be instructions or additional information for the Receiver, Intermediary, Account With Institution or Beneficiary Institution.
This field corresponds to field 72 of the S.W.I.F.T. message. The format of the message depends on the type of S.W.I.F.T. message that is generated. Refer to the S.W.I.F.T. manual for details on the format of the message and the code words to be used.
Clearing Network
Cover details for local clearing will capture Clearing Network. This clearing network will be defaulted during Contract Input and be used subsequently for PC Product resolution while generating a PC contract.
Instrument Details
If you opt to settle a contract with an instrument, you should specify the type of instrument that you would use. For example, you could settle a contract using a Manager’s Check, a Check or a Demand Draft. You should also specify the number that identifies the instrument. This number will be printed on the instrument.
If the settlement is through an instrument, you cannot specify party details.
Note
Settlement through instruments is a feature applicable only for the Funds Transfer module of Oracle FLEXCUBE.
Cover By
Select the cover by as Message or Clearing.
Cover Required
Check this box if cover is required.
RTGS Payments
If the settlement chosen is one of the RTGS Nostro that is, RTGS outgoing Nostro account in case of Outgoing customer and Bank transfer and RTGS incoming Nostro in case of outgoing Direct Debit transfer then the system will check this check box as per the validations done in RTGS Network. The user cannot change this value.
RTGS Network
If in a RTGS Network the accounts are maintained as ‘Pay account’ or ‘Receiver Account’ during the save of settlement instruction, then a set of validations will be performed as mentioned below:
For Pay message, it will validate the intermediary (if intermediary is not present, the Account with Institution (AWI) will be validated and if the AWI is also not present then receiver will be validated) is a RTGS participant.
For Pay+ Cover message, it will validate that a receiver correspondent is a RTGS network participant.
When you settle a contract, funds may have to pass through a series of banks before it actually reaches the Ultimate Beneficiary. In the Parties screen, you can capture details of all parties involved in a contract.
These screens contain fields that can capture details of all the possible parties through whom the funds involved in a contract can pass. Depending on the type of contract you are processing, and the number of banks involved, you should enter details in these screens.
An Intermediary Reimbursement Institution is the financial institution between the Sender’s Correspondent and the Receiver’s Correspondent, through which the reimbursement of the funds will take place.
Country
Intermediary
The Intermediary in a contract refers to the financial institution, between the Receiver and the ‘Account with Institution’, through which the funds must pass.
The Intermediary may be a branch or affiliate of the Receiver or the ‘Account With Institution’, or an entirely different financial institution. This field corresponds to field 56a of SWIFT
Here you can enter either the:
Country
The Receiver’s Correspondent is the branch of the Receiver or another financial institution at which the funds will be made available to the Receiver. This field corresponds to field 54a of SWIFT. You can enter one of the following:
Country
Specify the country of the receiver’s correspondent. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
An Account with Institution refers to the financial institution, at which the ordering party requests the Beneficiary to be paid. The ‘Account with Institution’ may be a branch or affiliate of the Receiver, or of the Intermediary, or of the Beneficiary Institution, or an entirely different financial institution. This field corresponds to field 57a of SWIFT. You can enter one of the following:
If no selection is made for Account with Institution, all beneficiaries will appear for selection in the option list for Ultimate Beneficiaries in the Parties tab 2 screens. If a particular Ultimate Beneficiary is selected in Parties tab 2, then the Account with Institution for the selected ultimate beneficiary will appear by default in the AWI field in the Parties tab 1 screen.
Country
Specify the country of the account with institution. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
Note
Receiver of Cover
Specify the details of the Receiver of the cover message, which can be any one of the following:
Ordering Institution
The Ordering Institution is the financial Institution, which is acting on behalf of itself, or a customer, to initiate the transaction. This field corresponds to 52a of SWIFT. In this field, you can enter one of the following:
Country
Specify the country of the ordering institution. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
Ordering Customer
The Ordering Customer refers to the customer ordering the transfer. Here, you can enter the name and address or the account number of the Customer, ordering the transaction. This field corresponds to field 50 of SWIFT. You will be allowed to enter details in this field only if you have initiated a customer transfer (MT 103 and MT 102). In case of an MT 910, a credit confirmation message, the first line should contain number ‘1’ in option F of field 50.
Country
Specify the country of the ordering customer. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
Here, you can enter details of the institution in favor of which the payment is made. It is in reality the bank, which services the account of the Ultimate Beneficiary. This is applicable only in the case of bank transfers and not for customer transfers. This field corresponds to field 58a of SWIFT
You will be allowed to make entries into this field only for Bank Transfers (when the remitter and beneficiary of the transfer are financial institutions –MT 202). Here you can enter either:
Country
The Ultimate Beneficiary refers to the Customer to whom the amount of the component is to be paid. This field refers to field 59 (is this now 59A) of SWIFT. You can make entries into this field only for a customer transfer (MT 103 or MT 100). This would not be applicable for Bank Transfers, only for Customer Transfers.
You can also select an ultimate beneficiary account from the option list provided. Upon selection of the account, the Account with Institution of the selected ultimate beneficiary will appear by default in the AWI field in the Parties 1 tab. If no selection is made for AWI in the Parties tab 1 screen, then all accounts of ultimate beneficiaries existing in the system will be appear for selection.
Country
Specify the country of the ultimate beneficiary. This adjoining option list displays all valid country codes maintained in the system. You can choose the appropriate one.
Note
When the SWIFT message is captured in the ‘Settlement Message Details – Parties’ screen, the system will display the parties involved in the transaction based on the values that come in the fields 52, 54, 55, 56, 57 58 etc. However, you can change the parties by choosing the appropriate value from the respective option lists. In case of the messages MT 103, MT202 and MT210, the option lists will display only those BICs for which the option ‘BEI Indicator’ is unchecked in the ‘BIC Code Maintenance’ screen. However you can manually enter a BIC for which the option ‘BEI Indicator’ is checked. During message generation, the system will replace the BIC with the corresponding name and address of the party.
The number of banks/intermediaries involved in the transfer would, in practice depend on the:
Note
During the life-cycle of a contract you will be allowed to amend the details of a Settlement Instruction only for those components which are yet to be settled.
Beneficiary Institution for Cover
Country
External Counterparty Details
Select the Counterparty Bank from the option list provided. All the Counterparty Accounts pertaining to this Bank will appear for selection. On selecting the Counterparty Account, the system will default the Counterparty Name as maintained for that account. If at the time of selecting Counterparty Account, Counterparty Bank is Null, then the Counterparty Bank will also appear by default.
For processing direct debits you will also need to capture the Agreement ID of the counterparty in order to facilitate a cross-referencing between the Payment and the Direct Debit instruction when a reversal of payment is carried out due to rejection of the outbound DD.
The Post Accounting option is defaulted from the Settlements to Payment Product and UDF Mapping screen. If enabled this indicates that accounting entries maintained for the PC product should be posted for the PC contract initiated for Clearing.
Clearing Network
During Contract Input, Clearing Network in settlement screen will be defaulted with 'Clearing Network' maintained in local clearing section in settlement instruction. If
You can maintain the local clearing details here.
Ultimate Bank Code
Select the ultimate bank code from the adjoining option list.
Sender Receiver Participant
Specify the sender receiver participant.
Additional Identifier
Specify the additional identifier.
Payment Code
Specify the payment code.
Additional Information
Specify additional information, if any.
Nip Payer
Specify the nip payer.
Payer Identifier
Specify the payer identifier.
Declaration
Specify the declaration.
Supplement Id
Select the supplement Id from the adjoining drop-down list.
Payment Type
Select the payment type from the adjoining drop-down list.
No of Declaration
Specify the number of declaration.
Free text 1, 2 and 3
Specify free text, if any.
Reason 1, 2, 3 and 4
Specify the reason for repair.
Receiver Name
Specify the receiver name.
Address 1,2 and 3
Specify the address here.
Information 1, 2, 3, 4, 5 and 6
Specify the sender receiver information here.
Information 1, 2, 3 and 4
You can maintain the other details here.
Bank Operation Code
Transaction Code
This is the code for the transaction type. This field corresponds to field 26T of the MT103 message.
Instruction Code 1, 2, 3, 4 and 5
You can indicate the Instruction code that will be inserted in Field 23E of the MT103 message. You can specify a maximum of six instructions codes here. However, you cannot repeat any code that has already been specified. The options available are:
You can specify the additional information, if any, which would be inserted to qualify multiple Instruction Codes in Field 23E of the MT103 message. The instruction code description can only be maintained for the following instruction codes
You can select the Regulatory Reporting Details from the option list displaying the following values:
The chosen value will be inserted in Field 77B of the MT103 message.
Time Indicators
Time Indication, specifies one or several time indication(s) related to the processing of the payment instruction. Select the time indication code from the following values available in the option list:
In the Settlement Instructions screen you would have maintained the default values for fields in MT 103 messages that are generated in respect of contracts involving an entity, module, currency and branch combination.
When a contract is entered for the customer in any module, the values that you maintain here will be defaulted for MT 103 generation in respect of the contract, and you can view them in the Settlement sub-screen of the contract main screen.
While amending a contract, you can modify the settlement information on the following tabs:
Save the contract once you have made the required changes. The system validates the modified information as in case of a new settlements operation.
While processing a settlement, the system validates marking of an Amount Tag to Track Receivable or Track Payable Process.
If Amount Tag is marked to ‘Track Receivable’ or ‘Track Payable’ and ‘Eligible for AR-AP Tracking’ check box is checked for the CIF linked to the Settlement Account, then the system replaces the Settlement Account with the ‘GL for ARAP’ or ‘Payable GL for ARAP’, respectively. The GL is defaulted based on the derivation logic maintained at ‘ARAP Code maintenance’.
If the Customer is not marked for AR-AP Tracking at the Customer Level, then the system validates for the mapping of the selected GL to the Product & Component combination. If it is not mapped, then the system displays an override message.
If an ICCF Amount Tag is marked for ‘Track Receivable’ or ‘Track Payable’ and the Settlement Account is a GL then a record would be created in LQ Module. The AR/AP Code and GL are defaulted based on the details maintained at AR-AP Code Maintenance level.
The MIS Information of the contract is defaulted as MIS Information of the record created in LQ Module.
The following steps are involved for updating the records in LQ module, for LC, BC, FT, PC and CL contracts:
The following table gives the SWIFT message types that will be generated for the various transfers that can be initiated through Oracle FLEXCUBE.
Type of Transfer |
Message Type |
Customer Transfer |
MT 103/ MT 100 |
Customer Transfer with Cover |
MT 103/ 100 and MT 202 |
Bank Transfer |
MT 202 |
Bank Transfer with Cover |
MT 205 |
Bank Transfer for Own Account |
MT 200 |
Notice to Receive |
MT 210 |
Direct Debits |
MT 104 |
ACK Status |
MT 012 |
NAK Status |
MT 019 |
Sending a Fax copy of an MT 103
For outgoing transfers, you have the option to generate a fax copy of a Payment Message (MT 103) that is sent when the transfer is initiated (INIT). A fax copy of an MT 103 can be triggered for generation:
The format and content of the fax will be similar to the corresponding SWIFT Payment Message.
Note
A fax copy of an MT 103 can be sent to the counterparty of a transfer only if the Payment Message (PAYMENT_MESSAGE) was triggered at the transfer initiation event (INIT).
Generated with a Payment Message
While indicating the messages that should be generated at the event (INIT), you should also associate the pre-shipped advice type FAX_PMT_MSG to the event.
When the FT is authorized, the MT 103 is generated from the Outgoing Message Browser and the Fax copy is triggered for generation.
Generation of a Unique Reference Number for Field 20
If the ‘SWIFT_SILVER’ parameter has been set to ‘YES’ for your bank, during the funds transfer a unique reference number will be generated in field 20.
The unique reference number is a combination of the first 7 characters of the contract reference number, a single digit unique number and the last 8 characters of the contract reference number.
Note
The single digit unique number is obtained as follows:
For all credit type transfers (MT910, MT200, MT103, MT103P, MT202 and cover message) it would be ‘2’. If the cover message is also sent along with the payment messages then it would be ‘3’. For debit type transfers (MT210 and MT900) it would be ‘1’.
Due to this setup, during the Nostro reconciliation process, the internal reference number of transaction related to funds transfer module would be modified before comparison with the external reference number.
This message type is sent by or on behalf of the financial institution of the ordering customer directly or through a correspondent(s), to the financial institution of the beneficiary customer.
Given below is a list of fields present in an MT 103 message type.
Message Type |
Field Tag |
Description |
MT103 |
20 |
Transaction Reference Number. If the ‘SWIFT_SILVER’ parameter has been set to ‘YES’ for your bank, a unique reference number will be generated instead of the transaction reference number. |
32A |
Value Date, Currency Code and Amount |
50 (Ordering Customer) |
This information you have maintained for the Ordering Customer field in the Other Messages tab of the Settlements screen is defaulted here. For outgoing MT103, the first line should have number 1 present in option F. If the ordering customer specified is a valid BIC then the system will update field 50a with this BIC. If the BIC is not a valid code, the system will display the name and address of the customer instead (as per option K). |
52a (Ordering Institution) |
This field gets populated depending on your entry in the Ordering institution field. If the transfer has originated from a different bank, this field should contain the name of the Originating Bank. If you do not need this field, clear the data from this field. |
53a (Sender’s Correspondent) |
The information that is captured for the Receiver of Cover field in the Settlement Instructions screen is defaulted if a cover is sent. Else the BIC of the Nostro account is defaulted. |
53B |
This field gets populated only if there are multiple account relationships between the sender and the receiver correspondents. |
54a (Receiver’s Correspondent) |
This field gets populated based on your entry in the Receiver Correspondent field in the Settlement Instructions screen. The information available in this field can be deleted if you do not need it. |
55 (Third Reimbursement bank) |
This field Specifies the Receiver's branch, when the funds are made available to this branch through a financial institution other than that indicated in field 53a. |
56a (Intermediary) |
This information maintained for the Intermediary field is defaulted here. You can change it. |
57a (Account With Institution) |
The information maintained for the Account With Institution field is displayed here. You have the option of changing it. If the value for field 72 does not contain the string ‘/RCB/’ and field 55 is not null, then the value in field 55 will be displayed here. If field 55 is null, then the value in field 54 will be displayed here. |
59 (Beneficiary Customer) |
The information maintained in the Ultimate Beneficiary field is defaulted here. You have the option of deleting this information. Here you need to link this tag content to the customer account and sender to the counter party BIC. If the ultimate beneficiary of the transaction is a valid BIC, then this field will display the BIC. In case the beneficiary BIC is invalid, then the field value will be null. |
70 (Details of Payment) |
The Details of Payment captured in the Settlements screen will be defaulted here. |
71A |
Information is defaulted from the Charge Bearer field in the FT Contract screen. |
71F |
Sender’s Charges. |
71G |
Receiver’s Charges. |
72 (Sender to Receiver Information) |
If you have captured the ERI Currency and Amount in the Settlements screen the OCMT is populated along with the data in the Sender to Receiver information field in the Settlements screen. |
Note
Some of the fields like field 20 and 32A are generic in nature. The details pertaining to the other fields are defaulted from your maintenance in the Settlement Instructions screen.
Field 32A will display the credit amount and currency, while field 33B will display the debit amount and currency in case of cross-currency payments. In case of intra-European payments where ‘EUR’ is the only currency involved, field 33B will display the transaction amount. In such cases, input to field 33B will be mandatory.
The sender’s charge currency of previous banks in the payment chain will be appended in field 71F of an outgoing MT103. During the STP of an incoming MT103, the fields 32A and 33B will not be compared to fields 71F and 71G. While processing an incoming payment message where the value for field 71A is ‘OUR’ and 71G is also present, the system will compute the transfer amount by subtracting the receiver’s charges from the credit amount. Receiver’s charges will not be displayed in an outgoing MT 103.
The MT100, which is a customer transfer message, consists of 12 fields each having its own identity and field number.
Given below is a list of fields present in an MT 100 message type.
Message Type |
Field Tag |
Description |
MT100 |
20 |
32A |
This information you have maintained for the Ordering Customer field in the Other Messages tab of the Settlements screen is defaulted here. |
The information maintained for the Account With Institution field is displayed here. You have the option of changing it. |
The information maintained in the Ultimate Beneficiary field is defaulted here. You have the option of deleting this information. Here you need to link this tag content to the customer account and sender to the counter party BIC. |
71A |
Note
During Close operation of a consolidation if the PAYMENT_MESSAGE is linked as an advice to the INIT event for the PC product, then the following two message types are created -
The MT102 would consists of three sequences -
Mandatory Sequence A General Information |
20 |
M |
File Reference |
Accounting Entry Ref. |
23 |
M |
Bank Operation Code |
50a |
O |
Ordering Customer – (A or K) |
This field would be filled up only if the Ordering Customer for all the underlying FT Contracts is same. For outgoing MT102, the first line should have number 1 present in option F. |
52a |
O |
Ordering Institution – (A or B or C) |
This field would be filled up only if the Ordering Institution for all the underlying FT Contracts is same. |
26T |
O |
Transaction Type Code |
This field would be filled up only if the Transaction Type codes for all the underlying FT Contracts are the same. |
77B |
O |
Regulatory Reporting |
This field would be filled up only if the Regulatory Reporting for all the underlying FT Contracts are the same. |
71A |
O |
Details of Charges |
This field would be based on ‘Charge Whom’ and will be filled up only if ‘Charge Whom’ is same for all the underlying FT Contracts. |
36 |
O |
Exchange Rate |
This field would be filled up only if the Cr. Currency, Settlement Currency and Exchange Rate for all the underlying FT Contracts are the same and Cr. Currency <> Settlement Currency. |
Mandatory Repetitive Sequence B Transaction Details |
21 |
M |
Transaction Reference |
FT Contract Ref No |
32B |
M |
Transaction Amount |
OUR or SHA- Credit Currency and Credit Amount BEN - Credit Currency and (Credit Amount – Sender’s Charges) |
50a |
O |
Ordering Customer (A or K) |
This field would be filled up only if the Ordering Customer for the underlying FT Contracts differs. |
52a |
O |
Ordering Institution (A or B or C) |
This field would be filled up only if the Ordering Institution for the underlying FT Contracts differs. |
57a |
O |
Acct With Institution (A or C) |
Account With Institution details of FT Contract. |
59a |
M |
Beneficiary Customer (A or No letter) |
Beneficiary Customer details of FT Contract. |
70 |
O |
Remittance Information |
Payment Details of FT Contract. |
26T |
O |
This field would be filled up only if the Transaction Type codes for the underlying FT Contracts differ. |
77B |
O |
This field would be filled up only if the Regulatory Reporting for the underlying FT Contracts differs. |
33B |
O |
Currency/Instructed Amount |
This field will be populated only if the Credit Amount <> 32B |
71A |
O |
This field would be based on ‘Charge Whom’ and will be filled up only if ‘Charge Whom’ for the underlying FT Contracts differs. |
71F |
O |
Sender’s Charges |
Sender’s Charges |
71G |
O |
Receiver’s Charges |
36 |
O |
Exchange Rate |
This field would be filled up in case the Currency Codes in Field 32B and 33B are different. |
Mandatory Sequence C Settlement Details |
32A |
M |
Value Date, Currency Code, Amount |
Sum of all (Amounts in 32B + Sum of Receiver’s Charges if Charge Whom = ‘OUR’ else this is equal to the Amount in 32B) |
19 |
O |
Sum of Amounts |
Sum of all amounts in 32B |
71G |
O |
Sum of Receiver’s Charges |
53a |
O |
Sender’s Correspondent |
Sender’s Correspondent. |
54a |
O |
Receiver’s Correspondent |
72 |
O |
Sender to Receiver Information |
The End of Transaction Input (EOTI) process will display an error message if there are some pending consolidated transactions in MT102 consolidation queue.
The following will be the sequence of processing incoming swift message MT 102:
Tag 57A is Same as Receiver of the message
Tag 57A is not present
If above condition is not satisfied then message would be rejected.
Dr. Sender’s NOSTRO (Consolidated Amount)
Cr. MT102 Incoming Suspense GL maintained at Branch level (Consolidated Amount)
A field called ‘Multi Credit Ref No’ will be available in the Incoming Browser. This would be populated for all the MT103 generated due to an incoming MT102 and would be populated with the value of tag 20 in Sequence A of the MT102.
In Oracle FLEXCUBE, you need to capture specific information against each field number for the Amount Tag – TRF_AMT.
Message Type |
Field Tag |
Description |
MT200 |
20 |
Transaction Reference Number. This message type should not start or end with a ‘/’ or ‘//’. This displays the Contract Reference number for most contracts. For an LC, BC and LD message, the user reference number is displayed. For an FT message, the source reference number is displayed. If the ‘SWIFT_SILVER’ parameter has been set to ‘YES’ for your bank, a unique reference number will be generated instead of the transaction reference number. |
21 |
Related Reference Number. This is the contract reference number in most cases. However, for a Money Market confirmation message, the common reference number of the contract is displayed in this field. For an LC message, the user reference number is displayed. For an FT message, the source reference number is displayed. |
32A |
53B (Sender’s Correspondent) |
Your entry for Our Correspondent in the Settlement Instructions screen is defaulted here. |
Your entry for the Intermediary field in the Settlement Instructions screen is defaulted here. |
Your entry against the Account With Institution field in the Settlement Instructions screen id defaulted here. |
All information pertaining to this message should be captured against the amount tag TRF_AMT.
Message Type |
Field Tag |
Description |
MT 202 |
20 |
21 |
32A |
Your entry for Ordering Institution in the Settlement Message Details screen is defaulted here. If the transfer is originating from a different bank you will need to capture the relevant data in this field. You will also need to capture information if the ordering institution is different from the Sending institution. |
This is field 54 of the corresponding MT103. During STP, if this field is null in the incoming message, the system will not send an outgoing MT202. It will only book an incoming payment. |
58a (Beneficiary Institution) |
The details of the receiver in the corresponding MT100 are defaulted here. You can capture the BIC code or the CIF Number assigned to the bank in this field. |
Note
In MT103, MT103P and MT202 if the value in field 52 (Ordering Institution) is the same as the sender’s correspondent, then field 52 will be suppressed during message generation.
This message is sent by the Receiver of a category 2 transfer message, i.e., MT 200, 201, 202, 203 or 205, directly or through correspondent(s), to another financial institution located in the same country as the Sender. It is used to further transmit a funds transfer instruction domestically.
Message Type |
Field Tag |
Description |
MT 205 |
20 |
21 |
Related Reference |
32 A |
52 a |
Ordering Institution |
53 a |
56 a |
Intermediary |
57 a |
Account With Institution |
58 a |
Beneficiary Institution |
72 |
For customer credit transfers, you can send the outgoing payment messages in MT 202 COV or MT 205 COV formats, if the receiver currency supports these formats.
Status |
Tag |
Field Name |
Content/Options |
M |
20 |
Transaction Reference Number |
16x |
M |
21 |
Related Reference |
16x |
O |
13C |
Time Indication |
/8c/4!n1!x4!n |
M |
32A |
6!n3!a15d |
O |
52a |
A or D |
O |
53a |
Sender's Correspondent |
A, B, or D |
O |
54a |
Receiver's Correspondent |
A, B, or D |
O |
56a |
Intermediary |
A or D |
O |
57a |
A, B, or D |
M |
58a |
A or D |
O |
72 |
6*35x |
End of Sequence A General Information |
Mandatory Sequence B underlying customer credit transfer details |
M |
50a |
Ordering Customer |
A, F, or K |
O |
52a |
A or D |
O |
56a |
Intermediary Institution |
A, C, or D |
O |
57a |
A, B, C, or D |
M |
59a |
Beneficiary Customer |
No letter option or A |
O |
70 |
4*35x |
O |
72 |
6*35x |
O |
33B |
3!a15d |
End of Sequence B underlying customer credit transfer details |
M = Mandatory, O = Optional |
For non-STP contracts, booked from any module, outgoing messages are generated in the new COV format depending on the transfer type, the value specified for the ‘Cover Required’ option, the country codes of the sender and receiver provided that the receiver currency supports the new formats. The following message types are used to handle the cover messages in the new format:
The cover message format to be used during message generation is derived as follows:
FT products with the transfer type as ‘CustomerTransferCover’ will be used to handle the incoming SWIFT messages. The cover message format to be used during message generation is derived as follows:
Message Type |
Field Tag |
Description |
MT 210 |
20 |
21 |
25 |
Account Identification |
30 |
Value Date |
21 |
Related Reference Number. |
32B |
The information captured in the Ordering Customer details field will be defaulted here only if the details are different from the Ordering Institution. For outgoing MT210, the first line should have number 1 present in option F. |
This is the BIC of the Sending Bank. The information maintained in the Ordering Institution field of the Settlement Message Details screen is defaulted here. If the BIC of the ordering institution and sending bank are the same, this field generation in the message is mandatory. |
The information captured in the Intermediary field of the Settlement Message details screen is defaulted to this field. You have the option of deleting the information captured in this field. |
Message Type |
Field Tag |
Description |
MT 320 |
20 |
Transaction reference Number. If the ‘SWIFT_SILVER’ parameter has been set to ‘YES’ for your bank, a unique reference number will be generated instead of the transaction reference number. |
21 |
Related Reference Number |
22 |
Code/Common Reference |
30 |
Date Contract Agreed/Amended |
31C |
Maturity Date of Deposit |
32a |
Value Date of Deposit, Currency Code. Contract Amount. |
33a |
Value Date for Change, Currency Code, Principal Amount to be Transferred. |
34a |
Next interest Due Date, Currency Code, interest Amount |
37a |
Interest Field |
22A |
NEWT/AMND depending on whether the contract is being booked or amended. |
22C |
Common Reference Number according to the SWIFT validation rules. |
30T |
Booking date of the contract |
30V |
Value Date of the contract |
30P |
Maturity Date of the contract |
32B |
Contract Currency and Contract Amount |
30X |
Next interest date in case of schedules else Maturity Date. |
34E |
Currency and Interest amount. |
37G |
Interest Rate |
14D |
Interest calculation basis in ICCF screen for interest. |
15C |
LENDING |
The information associated with the amount tag PRINCIPAL is defaulted from the Settlement Instructions screen. |
53A/53D |
Account holder of the settlement account |
56A/56D |
Details entered in the intermediary field in the settlement instruction screen. |
57A/57D |
Details entered in the Account With Institution field in the Settlement Instruction screen. |
58A/58D |
Details entered in the Beneficiary Institution field in the Settlement Instruction screen. |
BORROWING |
The information associated with the amount tag PRINCIPAL_LIQD is defaulted from the Settlement Instructions screen. |
53A/53D |
56A/56D |
57A/57D |
58A/58D |
15D |
LENDING |
53A/53D |
The details entered in the Receiver’s Correspondent field are defaulted in this field. |
56A/56D |
Details entered in the Intermediary field in the Settlement Instructions screen are defaulted in this field. |
57A/57D |
Details entered in the Account With Institution field in the Settlement Instruction screen are defaulted here. |
58A/58D |
Details entered in the Beneficiary Institution field in the Settlement Instruction screen are defaulted here. |
BORROWING |
53A/53D |
Details entered in the Receiver’s Correspondent field in the Settlement Instructions screen are defaulted here. |
56A/56D |
Details entered in the Intermediary field of the Settlement Instructions screen are defaulted here. |
57A/57D |
58A/58D |
Message Type |
Field Tag |
Description |
MT 300 |
15A |
New Sequence |
22A (Scope of Operation) |
NEWT/AMND depending on Contract booking or Amendment. |
22C (Common Reference) |
Common Reference Number, according to the SWIFT validation rules. |
30T (Trade Date) |
Booking date for the Contract Booking (NEWT) event. Event date for all other events. |
30V (Value Date) |
Bought Value Date. |
36 |
Exchange Rate |
32B (Bought Currency, Amount) |
The information pertaining to these fields is picked up from the settlement detailed maintained for the Amount Tag – SETBOTAMT. |
53a (Delivery Agent) |
The details entered in the Receiver's Correspondent field in the settlement Instructions screen are defaulted here. |
56a (intermediary) |
The details entered in the Intermediary field in the Settlement Instructions screen. |
57a (Receiving Agent) |
Details entered in the Account With Institution field in the Settlement Instructions screen. If the data is not available then the field will be populated with UNKNOWN according to the SWIFT requirements. |
33B (Sold Currency and Sold Amount) |
The information pertaining to these fields is picked up from the settlement detailed maintained for the Amount Tag – SETSOLDAMT. |
53 (Delivery Agent) |
The delivery agent is the account holder of the settlement account for SETSOLDAMT. |
56 |
The details entered in the intermediary field in the settlement instructions screen. |
The details entered in the Account With Institution field in the Settlement Instructions screen. If the data is not available then the field will be populated with UNKNOWN according to the SWIFT requirements |
58 |
The details entered in the Beneficiary Institution field in Settlement Instructions for the Amount Tag SETBOTAMT |
The receiver of the MT400 is the Remitting bank. The details are captured in the Parties section of the Settlements screen.
If the Remitting bank is not a customer of your bank, you can use the CIF ID assigned to the walk-in customer. You will also have to capture the SWIFT address of the remitting bank.
If the Remitting bank is not a customer of your bank and you have used the CIF ID assigned to the walk-in customer you will have to change the media to SWIFT in the Advices/FFT tab for generating the Collection Payment advice (COLL_PAY_ADV).
If you choose not to send an MT 400, the message can be suppressed in the Advices/FFT screen. A MT100 and MT202 (Cover) can be send instead by choosing the Cover Required option in the Settlements Instruction screen.
Message Type |
Field Tag |
Description |
MT400 |
53A/D (Sender’s/ Receiver’s Correspondent) |
The receiver of MT202. The information captured in the Receiver field of the Settlement Instruction screen for the Amount Tag BILL_LIQ_AMT is defaulted here. This field is not populated if the receiver of MT400 is same as Our Correspondent. |
54A/D and 57A/D |
If you would like both field 54 and 57 to appear in the generated message you will have to capture the relevant data in the Receiver Correspondent and Account With Institution fields against the Amount Tag BILL_LIQ_AMT. If only field 54 is required in the SWIFT message, you will have to capture data in the Account With Institution field and leave the Receiver Correspondent field blank. Consequently, the accompanying MT202 shall contain fields 54 and 57 depending on the availability of data in Receiver Correspondent and Account With Institution fields respectively. |
Note
The information pertaining to fields 20 (Sending Bank’s TRN), 21 (Related Reference), 32a (Amount Collected), 33A (Proceeds Remitted), is picked up from the contract details screen.
In Oracle FLEXCUBE, a new parameter CSTB_PARAM is introduced. The account number indicated in the party identification fields 56a and 57a of the MT 300/320/330 are serviced and not owned by the party indicated in the same field. If the value of this parameter is ‘Y’ and if the account lines of fields 56 & 57 do not have sort codes, then:
Based on the value of the parameter CSTB_PARAM, the incoming message processing will fetch the account number for pay and receive. If the parameter value is ‘Y’, the account number is fetched from field 56 instead of field 57. Otherwise, the account number of pay and receive will be fetched from field 57.
The receiver of the MT756 is the Remitting/ Negotiating bank. The details are captured in the Parties screen.
If the Remitting bank is not a customer of your bank and you have used the CIF ID assigned to the walk-in customer you will have to change the media to SWIFT in the Advices/FFT tab for generating the Reimbursement Payment advice (REIM_PAY_ADV).
If you choose not to send an MT 756, the message can be suppressed in the Advices / FFT screen. An MT100 and MT202 (Cover) can be sent instead by choosing the Cover Required option in the Settlements Instruction screen.
Message Type |
Field Tag |
Description |
MT 756 |
53A/D (Sender’s Correspondent) |
The receiver of MT202. This is the data input in the receiver field in the Settlement Instruction screen for the Amount Tag BILL_LIQ_AMT. This field is not populated if the receiver of the MT756 is the same as Our Correspondent. |
54A/D (Receiver’s Correspondent) |
Your entry for this field should be provided in the Account With Institution field in the Settlement Instructions screen for the Amount Tag BILL_LIQ_AMT. The data in this field will appear as 57A in the accompanying MT202. |
72 |
Sender to Receiver Information. |
MT 910 |
50 |
This is mandatory and needs to be validated. |
52a |
56a |
This field is populated with the institution from which sender received the funds. This is applicable only if the institution is different from the ordering institution. |
Note
The information pertaining to fields 20 (Sending Bank’s TRN), 21 (Presenting Bank’s Reference), 32B (Total Amount Claimed), 33A (Amount Reimbursed or Paid), is picked up from the contract details screen.
In PC contract online is provided with ACK Status having values -
After message dispatch, the ACK status is updated to ‘Pending’. Subsequently during processing of MT012 status changed to ‘ACK’ ad ‘ACK Status’ is updated in Transaction online and Transaction Summary screen also.
Incoming Swift Upload process support MT012 would contain either
Reference number present in field 108 of MT012 is searched first in PC Contract and upon receiving MT012, the ACK_STATUS of the record is marked to ACK. In case of the record not getting updated in the Contract Master, the message table is queried for DCN in field 108 to obtain the reference no. of the corresponding PC Contract and the ACK_STATUS is marked as ACK.
After message dispatch, the ACK status is NAK during processing of MT019 changing the status to ‘NAK’. Subsequently ‘NAK Status’ is updated in Transaction online and Transaction Summary screen also.
Incoming Swift Upload process support MT019 would contain either
Reference number present in the field of MT019 is searched first in PC Contract and upon receiving MT019; the NAK_STATUS of the record is marked to NAK. In case of the record not getting updated in the Contract Master, the message table is queried for DCN in the field to obtain the reference no. of the corresponding PC Contract and the NAK_STATUS is marked as NAK.
Given below are some examples of the SWIFT messages discussed above.
Example I – Customer Transfer
Ms. Tanya Agnihotri, a customer of your bank (Bank Austria Vienna) instructs you to transfer Dutch Guilders 100,000 to the account of Ms. Tina Shenoy with Citibank, Mumbai, for her birthday.
Message Details |
Format |
Explanation |
Sender |
BKAUATWWA |
The BIC Code assigned to Bank Austria, Vienna |
Message Type |
103 |
Receiver |
CITIBKINMU0 |
The BIC Code assigned to Citibank, Mumbai. |
Message Text |
Sender Reference |
:20:494931/DEV |
:23b:CRED |
Value date/ Currency/ Interbank settled amount |
: 32A:020426NLG100000, |
Field 32 A of SWIFT |
Ordering Customer |
:50K:Tanya Agnihotri |
Field 50 K of SWIFT |
:53B:CITIBKUSNY1 |
Field 53 B of SWIFT. The correspondent bank is Citibank, New York |
Ultimate Beneficiary |
:59:Tina Shenoy |
Field 59 of SWIFT |
Details of Payment |
:70: Birthday Gift |
Field 70 of SWIFT |
Example II - Payment Order — MT 202
Message Details |
Format |
Explanation |
Sender |
BKAUATWWA |
Message Type |
202 |
Receiver |
CITIBKUSNYX |
Message Text |
:20:203998988 |
Related Reference |
:21:494931/DEV |
Field 20 of MT 103 |
Value date/ Currency code/ Amount |
:32A:020426NLG100000, |
:58:CITIBKINMU0 |
Field 57a of SWIFT The bank is Citibank Mumbai. |
End of message text/trailer |
Example III - MT 200
You, (Bank Austria, Vienna) order Citibank, NY to transfer NLG 1 Million from your Nostro account with them, to your Nostro account with HDFC bank, Mumbai.
An Intermediary can be involved in this transfer, if Citibank, NY, requests Citibank, Mumbai, to transfer the funds to HDFC, Mumbai. In this case Citibank, Mumbai will be the Intermediary.
Example IV - MT 202
In the example for MT 200, if you involve an Intermediary (field 56a of SWIFT ) then a cover MT 202 will be sent to Citibank, Mumbai.
Example V - Notice to Receive (MT 210)
As a result of a Foreign Exchange deal with HDFC, Mumbai, you at Bank Austria, Vienna, are expecting to receive 1 Million USD to be credited to your account with Citibank, NY.
Notice To Receive: MT210
Field In Oracle FLEXCUBE |
Corresponding Field in SWIFT |
Entry |
Field 52a of SWIFT |
HDFC, Mumbai |
Sender |
Intermediary |
Field 56a of SWIFT |
Citibank, Mumbai |
Field 70 of SWIFT |
A message that you want to send. |
The Notice to Receive MT 210 will be sent from Bank Austria, Vienna, to Citibank, New York.
Example VI - Debit Advice (MT 900)
An MT 900 is a debit advice. It is sent by the Account Servicing institution to notify an account owner of an entry that has been debited to its account.
Bank Austria, Vienna asks Citibank, NY, to pay Citibank, Mumbai by debiting Bank Austria’s account with Citibank, New York.
An MT 900 is sent by Citibank, NY, after it pays Citibank, Mumbai and debits Bank Austria’s account with it.
This message type will be generated in case instrument to be issued in FCY. The receiver of the MT110 will be the BIC code for the customer of the NOSTRO account of Payable Bank.
Explanation |
Message Contents |
Message Type |
110 |
Receiver |
BIC of the customer corresponding to the Nostro A/C of the Liquidation product’s ARC setup |
Message Text |
Transaction reference number |
:20:Contract Ref no of the DD/PO transaction |
Number of the Cheque |
:21: Instrument Number from the DD Transaction |
Date the Cheque was issued |
:30:Instrument Date from DD/PO transaction |
Currency and Amount of cheque |
:32B: Instrument Currency Instrument Amount |
Payee of the Cheque |
:59: Beneficiary Name |
End of Message text/trailer |
Note
The DD/PO will be generated as per below sample format:
ISSUE BRANCH : _ISSBRN_ _ISSBRNDESC_
_ISSADDR1_
_ISSADDR2_
_ISSADDR3_
PAYABLE AT : _PAYBRN_ _PAYBRNDESC_
_PAYBANK_
Draft No. : _INSTRNO_ _INSTRTYPE_
_INSTRTYPEDESC_
Date : _INSTRDATE_
Amount : _INSTRCCY_ _INSTRAMT_
_INSTRAMTWORDS_
BENEFICIARY: _BENNAME_
_BENADDR1_
_BENADDR2_
_BENADDR3_
_BENADDR4_
_BENADDR5_
This message is exchanged by or on behalf of the financial institutions, Party A and Party B, who have agreed to a single or cross currency interest rate derivative transaction, including caps, collars and floors.
This message may be used to:
Maximum Length: 2000
Field Tag |
Field Name |
Format |
Mandatory/Optional |
15A |
New Sequence |
Empty field |
M |
20 |
Sender's Reference |
16x |
M |
21 |
Related Reference |
16x |
O |
22A |
Type of Operation |
4!c |
M |
94A |
Scope of Operation |
4!c |
O |
22C |
Common Reference |
4!a2!c4!n4!a2!c |
M |
23A |
Identification of the Swap |
10a/5a |
M |
21N |
Contract Number Party A |
16x |
M |
21B |
Contract Number Party B |
16x |
O |
30V |
Effective Date |
8!n |
M |
30P |
Termination Date |
8!n |
M |
82a |
Party A |
A or D |
M |
87a |
Party B |
A or D |
M |
83a |
Fund or Beneficiary Customer |
A, D, or J |
O |
29A |
Contact Information |
4*35x |
O |
72 |
6*35x |
O |
Optional Sequence B Interest Rate/Principal Payable by Party B |
Field Tag |
Field Name |
Format |
15B |
New Sequence |
Empty field |
M |
33F |
Calculation Notional Currency and Amount |
3!a15d |
M |
30X |
Period Start Date |
8!n |
M |
30Q |
Period End Date |
8!n |
O |
37G |
Reset Rate |
[N]12d |
M |
37J |
Cap Rate |
12d |
O |
37L |
Floor Rate |
12d |
O |
37R |
Spread |
[N]12d |
M |
37M |
Total Rate |
[N]12d |
M |
30F |
Payment Date |
8!n |
M |
32H |
Currency, Interest Amount |
[N]3!a15d |
O |
33E |
Currency, Principal Exchange Amount |
3!a15d |
O |
37N |
Details of Interest Rate |
6*35x |
O |
Optional Sequence C (Net) Amount(s) Payable by Party B |
Field Tag |
Field Name |
Format |
15C |
New Sequence |
Empty field |
M |
18A |
Number of Repetitions |
5n |
M |
30F |
Payment Date |
8!n |
M |
32M |
Currency, Payment Amount |
3!a15d |
M |
53a |
Delivery Agent |
A or D |
O |
56a |
Intermediary |
A or D |
O |
86a |
Second Intermediary |
A or D |
O |
57a |
Receiving Agent |
A or D |
M |
Optional Sequence D Interest Rate/Principal Payable by Party A |
Field Tag |
Field Name |
Format |
15D |
New Sequence |
Empty field |
M |
33F |
3!a15d |
M |
30X |
Period Start Date |
8!n |
M |
30Q |
Period End Date |
8!n |
O |
37G |
Reset Rate |
[N]12d |
M |
37J |
Cap Rate |
12d |
O |
37L |
Floor Rate |
12d |
O |
37R |
Spread |
[N]12d |
M |
37M |
Total Rate |
[N]12d |
M |
30F |
Payment Date |
8!n |
M |
32H |
[N]3!a15d |
O |
33E |
3!a15d |
O |
37N |
6*35x |
O |
Optional Sequence E (Net) Amount(s) Payable by Party A |
Field Tag |
Field Name |
Format |
15E |
New Sequence |
Empty field |
M |
18A |
5n |
M |
30F |
Payment Date |
8!n |
M |
32M |
3!a15d |
M |
53a |
Delivery Agent |
A or D |
O |
56a |
Intermediary |
A or D |
O |
86a |
A or D |
O |
57a |
Receiving Agent |
A or D |
M |
During STP, the system picks up an incoming MT362 message and extracts the following details from Sequence D for auto confirmation:
After the above details are extracted, the corresponding interest and principal schedule on that date is compared with the details extracted as mentioned above. The following details are considered for matching:
If the details match, the schedule will be marked as ‘Confirmed’. The same approach is followed for party B whose details are extracted from sequence B of the message. After the message is processed, the message is marked as ‘Processed’. You can view the message status in the incoming browser. After the corresponding schedules are marked as confirmed, they can be viewed in the contract confirmation screen. After confirmation, ‘Media’ will be updated as ‘SWIFT’ and ‘Authorization Status’ as ‘Auto’ in this screen.
RCON is triggered post confirmation and can be viewed under ‘Contract Online’ screen.
Oracle FLEXCUBE allows you to generate SWIFT Messages for transactions. MT920 is a transaction message requesting latest information available for the particular account. The request will be to transmit account customer statement message (MT940) or Balance report (MT941) or Interim statement (MT942) or a customer summary statement (MT950).
You need to generate the MT920 message. You can do this in the ‘Generate MT920’ screen. To invoke this screen, type ‘MSDGT920’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
Specify the following details:
Receiver
In the Generate MT920 screen, you can select the receiver of the message. The system shows only those receivers whose details you have maintained in the customer maintenance with MT920 as Y.
Reference No.
After providing the receiver details, click ‘P’ button. Based on this the system generates the new reference number
Details
Under Details in the Generate MT920 screen, provide the following details about the chosen receiver:
Customer No
Under Details, select the required ‘Customer No’ from the options listed. In the list you can find only those customer numbers maintained for the receiver in customer BIC maintenance with MT920 flag as Y
Account No.
Select the relevant account number of the customer from the available options. In the list, you will find only those Account numbers maintained for the receiver (BIC) and the Account in customer BIC maintenance.
Message
Select the message requested by the customer here.
Currency
Indicate the preferred currency of the customer.
Dr/(Dr and Cr) Floor Limit
Specify the debit floor limit of the customer. If the credit floor limit is not separately specified, this will indicate both the debit and the credit floor limits.
The system will pick the debit/credit transactions above this limit for customer account statement report.
This is mandatory for MT942 message type.
Cr Floor Limit
Specify the credit floor limit of the customer. The system will pick the credit transactions above this limit for customer account statement report.
If you specify the credit floor limit, you must also specify the debit floor limit. However, if you do not specify the credit floor limit, the system will consider the limit specified in the field ‘Dr/(Dr and Cr) Floor Limit’ for both credit and debit floor limits.
On save and authorization of the Maintenance, system generates the outgoing SWIFT message namely MT920.
If you click ‘Message’ button, the system will display the outgoing MT920 message separately.
When the incoming message is MT920 and the requested message is 940 (customer account statement) message, the system sends back the SWIFT Message, MT940 with response.
When the incoming message is MT920 and the requested message is MT941, the system sends back the SWIFT Message, MT941 with response.
When the incoming message is MT920 and the requested message is MT942, the system sends back the SWIFT Message, MT942 with response.
When the incoming message is MT920 and the requested message is MT942, the system sends back the SWIFT Message, MT950 with response.
Thus, the system, which uploads an MT920 message, is also able to generate an outgoing MT940, MT941, or MT942 Swift Messages.
