Assuming that the dimension table and fact table is loaded with relevant data, cube can be built.
Define batch to execute the CREATE CUBE component that will build the outline and load data in ESSBASE.
For more information on executing the batch, see Oracle Financial Services Analytical Applications Infrastructure User Guide.
